I recieve a "No Results Found" message when I try to get a route. They are all valid address that I was able to import using a CSV, so I know that Arc can find them. I have tried removing the "Return to start" and "optimize stop order", but that does not help either. Has anyone else run into this? I have attached my spreadsheet with the addresses, nmf file (i had to remane it as a .pdf so it could be uploaded, for some reason this forum doesn't let you upload projects for the application it focusses on...), and a screen shot of the issue.
