AnsweredAssumed Answered
DeleteFeatures Behavior Changed in ArcSDE 10.1  / SQL Server 2012
Question asked by kreuzrsk on Sep 5, 2014
Latest reply on Sep 5, 2014 by kreuzrsk
DeleteFeatures no longer deletes all records at one time which it's supose to do when the input is a feature class or table!  We upgraded from ArcGIS 10.0 / SQL 2008 to ArcGIS 10.1 / SQL 2012 so I don't know which caused the change.  In 10.0 this was carried out all at once in like a truncate on the database side, but after upgrading it's taking forever now.  Through SQL Profiler I can see that the records are being deleted in batches of about 150 records at a time, so what use to take about 2 to 3 seconds now takes over 30 minutes for a feature class containing a 1,000,000 records.  Is there any fix for this?
BTW, this is similar to a bug introduced back in 9.3.1
https://community.esri.com/message/16613?sr=search&searchId=27c4082a-5048-443b-ab3e-d38219e3b633&searchIndex=4#16613
-- sample from SQL profiler --
declare @p1 int
set @p1=8003
exec sp_prepexec @p1
output,NULL,N'DELETE FROM GEOLIB_STAGE.DBO.TRANS WHERE OBJECTID IN
(8678,149031,781870,529051,850941,146097,548880,540263,435454,354365,529268,582084,247165,795180,559851,414179,446673,660244,490564,517760,142856,241123,695475,471813,307298,412080,719441,332785,592142,194167,188071,810130,824122,400725,570745,21179,375132,466956,743512,188859,661765,372015,794739,91259,138852,136984,883971,444122,485764,713000,134614,347483,503788,44012,840195,132928,875866,156734,523141,402599,752233,603552,330094,513428,53304,131004,803002,129594,498844,667558,90466,357945,633048,672060,479776,608211,820966,126915,265315,440638,677618,464150,236562,34384,749617,733983,658454,506931,764976,301637,532466,872429,19165,7489,252175,120581,409177,543996,163044,438198,534060,262530,872814,185194,325948,81350,576719,110589,181631,55689,398198,13743,348374,705618,417351,115767,853417,30666,733162,858712,256363,177822,683846,622061,827987,854389,200153,859952,871,296910,516844,385774,118935,665057,36949,631680,118086,428021,716597,783347,813725,878892,436661,336825,755693,225822,339504,355226,784398,584838)'
select @p1
Outcomes
