How do I remove layers with broken data sources?
3798
5
09-05-2014 08:54 AM
TedPrescott
New Contributor III
I need to scroll through an mxd and remove any layers that have broken data sources.
I have found
     brknList = arcpy.mapping.ListBrokenDataSources(inMXD)
and
for lyr in arcpy.mapping.ListLayers(mxd, "*",df):
arcpy.mapping.RemoveLayer(df, lyr)
both work well, but not together.
Any suggestions?
Tags (1)
IanMurray
arcpy Layer objects have a isBroken property you can check if is true or not.  If it is true, then have your script remove the layer, instead of all layers
try this:
for layer in arcpy.mapping.ListLayers(mxd, "*", df):
    if layer.isBroken:
        arcpy.mapping.RemoveLayer(df, layer)
TedPrescott
New Contributor III
It works GREAT !!!
Your few lines of code just saved me from several days of frustration.
Thanks for your prompt reply.
Ted
IanMurray
You are quite welcome.  Just out of curiousity, why are you needing to delete so many layers from so many map?
TedPrescott
New Contributor III
We have 15 years of legacy mxds and most have data sources long gone.
This way, I can log the broken data sources, remove them and then allow the end users to replace the data as needed.
Otherwise, it takes a VERY LONG TIME to open the mxds w/ all the broken data.
IanMurray
Yea that would be quite a pain to do manually.
If you don't mind can you mark this question answered, will make it easier for people to find in the future if they have a similar issue.
