Elevation profile geoprocessing service - error 000840
5441
9
09-04-2014 09:19 AM
ionarawilson1
Occasional Contributor III
I am trying to create an Elevation Profile service using the Python code found on the link:
http://www.arcgis.com/home/item.html?id=0d47b17d3b884b9d977a6f76fc6bfcaa
And I followed all the instructions. I am able to publish the geoprocessing service, but when I run the gp service inside ArcGIS I get an error saying:
Error executing tool.: Failed to execute. Parameters are not valid. ERROR 000840: The value is not a TIN Layer. ERROR 000840: The value is not a Raster Layer. ERROR 000840: The value is not a Terrain Layer. ERROR 000840: The value is not a LAS Dataset Layer. Failed to execute (InterpolateShape). Failed to execute. Parameters are not valid. ERROR 000840: The value is not a TIN Layer. ERROR 000840: The value is not a Raster Layer. ERROR 000840: The value is not a Terrain Layer. ERROR 000840: The value is not a LAS Dataset Layer. Failed to execute (InterpolateShape). Failed to execute (Profile). Failed to execute (Profile).
The problem seems to be in the Interpolate Shape analysis in line 307 but I am not sure what is wrong with it. Do you guys have any ideas? Here is the code below. Thank you so much!
""" Tool name: Profile
Source name: Profile Tool.pyt
Description: Return an elevation profile for an input polyline.
Author: Environmental Systems Research Institute Inc.
Last updated: Aug. 05, 2014
import os
import time
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Profile Tool"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [Profile]
class Profile(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Profile"
        self.description = "Return an elevation profile for an input polyline."
        self.canRunInBackground = False
        # custom properties
        self.debug = True
        self.outputToTable = False # set to True to direct the output to a table.
        self.idFieldName = "ID"
        self.glen_field1 = "proflen0"
        self.glen_field2 = "proflen1"
        self.metadataFieldName = "DEMResolution"
        self.geodesicLenFieldName = "ProfileLength"
        self.listLinearUnits = ["Meters", "Kilometers", "Feet", "Yards", "Miles"]
        # Maximum number of vertices
        self.maxNumVertices = 2000
        # DEM boundary layer
        boundaryLayer1 = "demboundary"
        if False:
            arcpy.Describe(boundaryLayer1)
        self.demBoundary = boundaryLayer1
        # Profile schema feature class
        profileSchm1 = r"D:\ArcGISData\ElevationProfile\ProfileData\dembnd.gdb\profileschema"
        self.profileSchema = profileSchm1
        # DEM resolution dictionary
        self.dictDEMResolutions = {"90m":"90", "30m":"30", "10m":"10"}
        self.defaultDEMResolution = '90'
        # DEM data layers
        # Define layer variables
        demLayer1 = "dem90m"
        demLayer2 = "dem30m"
        demLayer3 = "dem10m"
        # Wrap each variable in an arcpy.Describe statement
        if False:
            arcpy.Describe(demLayer1)
            arcpy.Describe(demLayer2)
            arcpy.Describe(demLayer3)
        # Update the DEM layers dictionary
        self.dictDEMs = {"90":demLayer1,
                        "30":demLayer2,
                        "10":demLayer3}
        # DEM coordinate system
        demSR = arcpy.Describe(self.dictDEMs.values()[0]).spatialReference
        self.demCoordinateSystem = demSR
        # DEM linear unit
        lun = demSR.linearUnitName
        if lun == "" or lun == None:
            lun = demSR.angularUnitName
            if 'degree' in lun.lower():
                lun = 'decimaldegrees'
        if 'foot' in lun.lower() or 'feet' in lun.lower():
            lun = 'feet'
        self.demLinearUnit = lun
        # for adjusting length, change the zf here. eg, if the DEM linear unit is feet, then zf = 0.3048.
        # for meter, zf = 1.0; for decimal degrees, use zf = 1.0
        self.zFactor = self.getUnitConversionFactor(self.demLinearUnit)
        self.errorMessages = ["No input polyline features specified. The input needs to have at list one line feature.",
                "Input resolution is not supported. Select a different DEM source.",
                "The input profile line you requested falls outside of the data currently available in this service.",
                "Input parameter {0} is not valid.",
                "The input polyline contains too many vertices. Reduce the number of vertices.",
                "The specified sample distance results in more vertices than allowed. Increase sampling distance.",
                "Input feature contains too many vertices or the sample distance is too small. Specify a line with less than 1024 vertices, or increase the sampling distance.",
                "Input sample distance cannot be 0 or negative.",
                "Input feature id field does not exist. Change to another field or leave it as default.",
                "The number of input profile lines exceeds limit. Reduce the number of input profile lines to not more than 10."]
    def getLayerName(self, res):
        if not res in self.dictDEMs.keys():
            arcpy.AddError(self.errorMessages[1])
            raise
            return
        return self.dictDEMs[res]
    def getUnitConversionFactor(self, u1): # get conversion factor
        uFactor = 1
        inUnit = u1.strip().lower()
        if inUnit in ["meters", "meter"]:
            uFactor = 1
        if inUnit in ["centimeters", "centimeter"]:
            uFactor = 0.01
        if inUnit in ["decimaldegrees", "decimaldegree"]:
            uFactor = 1
        if inUnit in ["decimeters", "decimeter"]:
            uFactor = 0.1
        if inUnit in ["feet", "foot"]:
            uFactor = 0.3048
        if inUnit in ["foot_us", "feet_us"]:
            uFactor = 0.3048006096012192
        if inUnit in ["inches","inch"]:
            uFactor = 0.0254
        if inUnit in ["kilometers", "kilometer"]:
            uFactor = 1000
        if inUnit in ["miles","mile"]:
            uFactor = 1609.344
        if inUnit in ["millimeters", "millimeter"]:
            uFactor = 0.001
        if inUnit in ["nauticalmiles", "nauticalmile"]:
            uFactor = 1852
        if inUnit in ["points", "point"]:
            uFactor = 0.000352777778
        if inUnit in ["unknown", ""]:
            uFactor = 1
        if inUnit in ["yards", "yard"]:
            uFactor = 0.91440
        return uFactor
    def lineFootprintTest(self, in_line_features):
        # Footprint polygon
        footPrt = self.demBoundary
        resList = []
        footPrtLayer = 'aFootPrtLyr'
        arcpy.MakeFeatureLayer_management(footPrt,footPrtLayer)
        arcpy.SelectLayerByLocation_management(footPrtLayer, "COMPLETELY_CONTAINS",
                                                in_line_features)
        self.traceExecutionTime("")
        with arcpy.da.SearchCursor(footPrtLayer, "res") as cursor:
            for row in cursor:
                resList.append(row[0])
        return resList
    def CountVerticesAndLength(self, in_polylines1):
        countL = 0
        countV = 0
        totalLen = 0
        individualLen = []
        list_oid = []
        list_vert = []
        list_geodesiclen = []
        with arcpy.da.SearchCursor(in_polylines1, ("Shape@", "Shape@Length", "OID@", self.glen_field2)) as cur:
            for row in cur:
                countL += 1
                countV += row[0].getPart(0).count
                totalLen += row[1]
                individualLen.append(row[1])
                list_oid.append(row[2])
                list_vert.append(row[0].getPart(0).count)
                list_geodesiclen.append(row[3])
        return (countL, countV, totalLen, individualLen, list_oid, list_vert, list_geodesiclen)
    def CountVerticesNoProjection(self, in_polylines1):
        countV = 0
        with arcpy.da.SearchCursor(in_polylines1, ("Shape@")) as cur:
            for row in cur:
        return countV
    def getResolutionByLength(self, in_len):
        dem_res = []
        if in_len < 5000:
            dem_res = [10, 30, 90]
        if in_len >= 5000 and in_len < 15000:
            dem_res = [30, 90]
        if in_len >= 15000:
            dem_res = [90]
        return dem_res
    def getResolutionByLengthFootprint(self, in_polylines, total_len):
        len_candidates = self.getResolutionByLength(total_len)
        foot_candidates = self.lineFootprintTest(in_polylines)
        foot_candidates_int = [int(x) for x in foot_candidates]
        res_list = [i for i in len_candidates if i in foot_candidates_int]
        res_list.sort()
        if len(res_list) == 0:
            arcpy.AddError(self.errorMessages[2])
            raise
        return res_list
    def getResolutionByFootprint(self, in_polylines):
        foot_candidates_int.sort()
        if len(foot_candidates_int) == 0:
            raise
        return foot_candidates_int
    def getDefaultNumberVertices(self, in_number_vertices):
        out_num = None
        if in_number_vertices <= 50:
            out_num = 50
        if in_number_vertices > 50 and in_number_vertices <= 200:
            out_num = 200
        if in_number_vertices > 200:
            out_num = in_number_vertices
        return out_num
    def densifyLine(self, in_line_features, distanceLU):
        if distanceLU != "": # only do it when not empty
                arcpy.Densify_edit(in_line_features, "DISTANCE", distanceLU)
    def weedLine(self, in_line_features, in_toler):
        if in_toler <> 0: # only do it when not 0
            arcpy.Generalize_edit(in_line_features, in_toler)
    def traceExecutionTime(self, msg):
        if self.debug:
            if msg <> None:
                arcpy.AddMessage(msg)
            arcpy.AddMessage(arcpy.GetMessages())
    def printCoordinateSystem(self, in_dataset):
        des = arcpy.Describe(in_dataset)
        arcpy.AddMessage(des.SpatialReference.name)
    def validateNumerical(self, inVal, paramStr):
        if inVal == None: # None is OK
            return
        elif inVal <= 0:
            arcpy.AddError(self.errorMessages[7].format(paramStr))
            raise
    def validateDistanceUnits(self, inStr, paramStr):
        tempUnitsList = [s.lower() for s in self.listLinearUnits]
        tempUnitsList.extend(["#", ""])
        if inStr == None: # None is OK
            return
        elif not (inStr.lower() in tempUnitsList):
            arcpy.AddError(self.errorMessages[3].format(paramStr))
            raise
    def validateInputDEMSource(self, inDEM):
        tempDEMList = [s.upper() for s in self.dictDEMResolutions.keys()]
        tempDEMList.extend(["", "FINEST", "#"])
        if inDEM == None: # None is OK
            return
        elif not (inDEM.strip().upper() in tempDEMList):
            arcpy.AddError(self.errorMessages[1].format(inDEM))
            raise
    def validateFeatureIDField(self, inName, inFeature):
        fldList = arcpy.ListFields(inFeature)
        fldListLower = [f.name.lower() for f in fldList]
        if inName == None: # None is OK
            return
        elif not (inName.lower() in fldListLower):
            arcpy.AddError(self.errorMessages[8])
            raise
    def formatInputDEMSource(self, inSource):
        tempDEMList = self.dictDEMResolutions.keys()
        tempDEMList.extend(["", "FINEST"])
        retVal = inSource
        for d in tempDEMList:
            if inSource.upper() == d.upper():
                retVal = d
                break
        return retVal
    def createProfile(self, in_line_features, inputIsInOcean, line_id_field, idFieldIsTemp, inputSR,
            dem_resolution, line_count, list_geodesiclen, out_profile):
        try:
            line_features_inputCS = os.path.join(r"in_memory", r"linetmpafterprj03")
            route_temp = os.path.join(r"in_memory", "outroutetmp")
            interp_line_temp = r"in_memory\interpouttmp"
            out_vertices_temp = r"in_memory\verticestmp"
            arcpy.env.workspace = "in_memory"
            # get Z values from DEM
            arcpy.InterpolateShape_3d(in_surface=self.getLayerName(dem_resolution),
                                     in_feature_class=in_line_features,
                                     out_feature_class=interp_line_temp,
                                     vertices_only="VERTICES_ONLY")
            # Calculate M values using Create Routes tool
            # By default, M is in meters. To change the M unit,
            # change the unit in which glen_field2 is calculated (in the execute method)
            arcpy.CreateRoutes_lr(in_line_features=interp_line_temp, route_id_field=line_id_field,
                                out_feature_class=route_temp, measure_source="TWO_FIELDS",
                                from_measure_field=self.glen_field1, to_measure_field=self.glen_field2)
            if self.outputToTable: # out to table
                # project the line
                arcpy.env.outputCoordinateSystem = inputSR  # convert to input projection
                arcpy.CopyFeatures_management(route_temp, line_features_inputCS) # project
                arcpy.env.outputCoordinateSystem = ""
                # extract X, Y, Z, M
                arcpy.CreateTable_management("in_memory", os.path.basename(out_profile), os.path.join(os.path.dirname(__file__), "profile_schema.dbf"))
                with arcpy.da.InsertCursor(out_profile, ("ID", "POINT_X", "POINT_Y", "POINT_M", "POINT_Z")) as icur:
                    with arcpy.da.SearchCursor(line_features_inputCS, ("Shape@", line_id_field)) as scur:
                        for row in scur:
                            geo = row[0]
                            id_val = row[1]
                            for l1 in geo.getPart():
                                for pnt in l1:
                                    x = pnt.X
                                    y = pnt.Y
                                    m = pnt.M
                                    z = pnt.Z
                                    icur.insertRow((id_val, x, y, m, z))
            else: # out to line
                # project the line
                arcpy.CopyFeatures_management(route_temp, out_profile) # project
                # Add metadata info
                if inputIsInOcean:
                    dem_source = ['1000m']
                else:
                    dem_source = [k for k, v in self.dictDEMResolutions.iteritems() if v == str(dem_resolution)]
                arcpy.AddField_management(out_profile, self.metadataFieldName, "TEXT", field_length=50, field_alias="DEM Resolution")
                arcpy.CalculateField_management(out_profile, self.metadataFieldName, "'" + dem_source[0] + "'", "PYTHON")
                # Add geodesic length for profile
                arcpy.AddField_management(out_profile, self.geodesicLenFieldName, "DOUBLE", field_alias="Length Meters")
                i = 0
                with arcpy.da.UpdateCursor(out_profile, self.geodesicLenFieldName) as ucur:
                    for row in ucur:
                        row[0] = list_geodesiclen
                        i += 1
                        ucur.updateRow(row)
                # remove tempid field
                if idFieldIsTemp:
                    arcpy.DeleteField_management(out_profile, line_id_field)
        except:
            msgs = arcpy.GetMessages(2)
            arcpy.AddError(msgs)
            raise
    def getParameterInfo(self):
        """Define parameter definitions"""
        param0 = arcpy.Parameter(name="InputLineFeatures",
                                 displayName="Input Line Features",
                                 direction="Input",
                                 parameterType="Required",
                                 datatype="GPFeatureRecordSetLayer")
        # Feautre set schema
        param0.value = self.profileSchema
        param1 = arcpy.Parameter(name="ProfileIDField",
                                 displayName="Profile ID Field",
                                 direction="Input",
                                 parameterType="Optional",
                                 datatype="Field")
        param1.filter.list = ['OID', 'Short', 'Long']
        param2 = arcpy.Parameter(name="DEMResolution",
                                 displayName="DEM Resolution",
                                 direction="Input",
                                 datatype="GPString")
        param2.filter.type = "ValueList"
        list_dem = [" ", "FINEST"]
        dem_keys = self.dictDEMResolutions.keys()
        dem_keys.sort()
        list_dem.extend(dem_keys)
        param2.filter.list = list_dem
        param3 = arcpy.Parameter(name="MaximumSampleDistance",
                                 displayName="Maximum Sample Distance",
                                 direction="Input",
                                 datatype="GPDouble")
        param4 = arcpy.Parameter(name="MaximumSampleDistanceUnits",
                                 displayName="Maximum Sample Distance Units",
                                 direction="Input",
        param4.filter.type = "ValueList"
        param4.filter.list = self.listLinearUnits
        param4.value = "Meters"
        param5 = arcpy.Parameter(name="OutputProfile",
                                 displayName="Output Profile",
                                 direction="Output",
                                 parameterType="Derived",
                                 datatype="DEFeatureClass")
        params = [param0, param1, param2, param3, param4, param5]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        try:
            startTime = time.time()
            self.debug = False
            in_polylines = parameters[0].value
            profile_id_field = parameters[1].valueAsText
            dem_resolution_p = parameters[2].valueAsText
            sample_distance_p = parameters[3].value
            sample_distance_units = parameters[4].valueAsText
            out_profile = os.path.join("in_memory", "profile1")
            maxInputLines = 100 # sync is 100, async is 1000
            if ("elevation_gpserver" in arcpy.env.scratchWorkspace):
                maxInputLines = 1000
            # Get input SR
            d0 = arcpy.Describe(in_polylines)
            inputSR = d0.spatialReference
            oidfld1 = d0.OIDFieldName
            # project first
            polylines_after_prj = os.path.join("in_memory", "inputlinetmp02")
            # project to raster coordinate system
            arcpy.env.outputCoordinateSystem = self.demCoordinateSystem
            arcpy.CopyFeatures_management(in_polylines, polylines_after_prj) # project
            # Add and calcualte geodesic length fields - from field and to field for
            # Create Routes tool to calculate the M values
            arcpy.AddField_management(polylines_after_prj, self.glen_field1, "DOUBLE")
            arcpy.CalculateField_management(polylines_after_prj, self.glen_field1,
                                "0", "PYTHON_9.3")
            # The unit in which glen_field2 is calculated determines the M unit.
            # To change it other units, replace meters below with desired units
            arcpy.AddField_management(polylines_after_prj, self.glen_field2, "DOUBLE")
            arcpy.CalculateField_management(polylines_after_prj, self.glen_field2,
                                "!shape.geodesiclength@meters!", "PYTHON_9.3")
            # validate profile id field
            time_a = time.time()
            self.validateFeatureIDField(profile_id_field, in_polylines)
            time_b = time.time()
            if self.debug:
                arcpy.AddMessage("ValidateFeatureIDField execution time: " + str(time_b - time_a))
            # make temp id field
            idFieldIsTemp = False
            temp_id_field = "tmpprflid_"
            if profile_id_field == None:
                idFieldIsTemp = True # needed for field removal later
                fieldSp = 0
                fieldIsObjID = 1
                profile_id_field = temp_id_field
            elif profile_id_field.lower() in ["oid", "fid", "objectid"]:
                fieldSp = 1
                fieldIsObjID = 0
            if profile_id_field == temp_id_field: # default
                arcpy.AddField_management(polylines_after_prj, profile_id_field, "LONG")
                arcpy.CalculateField_management(polylines_after_prj, profile_id_field, "!" + oidfld1 + "!", "PYTHON_9.3")
            # var for metering
            fieldSp = 1
            fieldIsObjID = 1
            samplingDistSp = 0
            # now find the line length and number of vertices
            lineFact = self.CountVerticesAndLength(polylines_after_prj)
            if self.debug:
                arcpy.AddMessage("CountVerticesAndLength execution time: " + str(time_b - time_a))
            line_counts = lineFact[0]
            total_num_vert = lineFact[1]
            total_len = lineFact[2]
            indiv_len = lineFact[3]
            list_oid = lineFact[4]
            list_vert = lineFact[5]
            list_glen = lineFact[6]
            if line_counts < 1:
                arcpy.AddError(self.errorMessages[0])
                raise
            elif line_counts > maxInputLines:
                arcpy.AddError(self.errorMessages[9])
                raise
            self.validateNumerical(sample_distance_p, "Maximum Sample Distance")
            self.validateDistanceUnits(sample_distance_units, "Maximum Sample Distance Units")
            self.validateInputDEMSource(dem_resolution_p)
            # trim dem_resolution_p
            if dem_resolution_p is not None and str(dem_resolution_p).upper() <> "FINEST":
                if dem_resolution_p.strip() == "":
                    dem_resolution_p = None
                if dem_resolution_p is not None:
                    dem_resolution_p = self.dictDEMResolutions[self.formatInputDEMSource(dem_resolution_p)]
            # determine whether input line is in ocean
            inputIsInOcean = False
            # determine resolution
            if str(dem_resolution_p).upper() <> "FINEST":
                if dem_resolution_p is None: # case 1 blank (default)
                    dem_resolution = self.defaultDEMResolution
                    res_list = self.getResolutionByFootprint(polylines_after_prj)
                    if not int(dem_resolution) in res_list:
                        raise
                        return
                else: # case 2 specified
                    dem_resolution = dem_resolution_p
                        raise
                        return
            else: # case 3 - FINEST:
                dem_resolution = str(int(res_list[0]))
            if sample_distance_units == None:
                sample_distance_units = "meters"
            outfeaturelayer1 = "tempfeaturelayer"
            arcpy.MakeFeatureLayer_management(polylines_after_prj, outfeaturelayer1)
            for oid_val in list_oid:
                query_exp = oidfld1 + "=" + str(oid_val)
                arcpy.SelectLayerByAttribute_management(outfeaturelayer1, "NEW_SELECTION", query_exp)
                in_len = indiv_len[list_oid.index(oid_val)] # individual line length
                in_glen = list_glen[list_oid.index(oid_val)] # individual glength
                ratio1 = in_len / (in_glen / self.zFactor) # ratio to convert to Mercator
                in_num_vert = list_vert[list_oid.index(oid_val)] # individual line vertex number
                if sample_distance_p == None: # default
                    samplingDistSp = 0 # metering
                    out_num_vert = in_num_vert
                    needDensify = False
                    needWeed = False
                    if in_num_vert < 50:
                        out_num_vert = 50
                        needDensify = True
                    elif in_num_vert >= 50 and in_num_vert < 200:
                        out_num_vert = 200
                        needDensify = True
                    elif in_num_vert >= 200 and in_num_vert <= self.maxNumVertices:
                        needDensify = False
                    elif in_num_vert > self.maxNumVertices:
                        out_num_vert = self.maxNumVertices
                        needDensify = False
                        needWeed = True
                    sample_distance_m = in_len / (out_num_vert - 1) # default sample distance
                    if needDensify:
                        # change the unit here to DEM linear unit, eg, feet, meters, decimaldegrees
                        self.densifyLine(outfeaturelayer1, str(sample_distance_m) + " " + self.demLinearUnit)
                    if needWeed:
                        self.weedLine(outfeaturelayer1, str(int(dem_resolution) / 4.0) + " " + self.demLinearUnit)
                else: # specified
                    samplingDistSp = 1 # metering
                    newSamplingDist = ratio1 * sample_distance_p # convert to GCS distance
                    sample_distance_m = newSamplingDist * self.getUnitConversionFactor(sample_distance_units) / self.zFactor # convert to Feet
                    nVert = int((in_len / sample_distance_m) + 1)
                    if nVert > self.maxNumVertices:
                        arcpy.AddError(self.errorMessages[5])
                        raise
                        return
                    else:
                # final count of no. vertices
                nVert1 = self.CountVerticesNoProjection(outfeaturelayer1)
                if nVert1 > self.maxNumVertices * 2:
                    arcpy.AddError(self.errorMessages[6])
                    raise
                    return
            # Execute the tool, line is already densified
            arcpy.AddMessage("DEM Resolution: " + dem_resolution + ", Sampling Distance: "
                               + str(sample_distance_m))
            self.createProfile(polylines_after_prj, inputIsInOcean, profile_id_field, idFieldIsTemp, inputSR,
                            dem_resolution, line_counts, list_glen, out_profile)
            arcpy.SetParameterAsText(5, out_profile)
        except:
JinZhang
New Contributor III
Executing: Profile C:\Users\zhangj\Documents\ProfileData\dembnd.gdb\profileschema # 10m # Meters
Start Time: Mon Oct 20 09:45:22 2014
Running script Profile...
DEM Resolution: 10, Sampling Distance: 170.262832632
Completed script Profile...
Failed at Mon Oct 20 09:45:26 2014 (Elapsed Time: 3.65 seconds)
Thank you and regards,
Jin
JinZhang
New Contributor III
I also got this error "The input profile line you requested falls outside of the data currently available in this service." Could someone please tell me what could be the possible cause?
Jin
ionarawilson
New Contributor III
I am not sure what we did to fix it .  I think  because we only needed to work with 10 meters, we did not need the other DEMs so we changed from
  1. demLayer1 = "dem90m"
  2.         demLayer2 = "dem30m"
  3.         demLayer3 = "dem10m"
to
demLayer1 = "dem10m"
        demLayer2 = "dem10m"
Your last error seems to indicate you are selecting an area outside the area that ESRI created the DEM for. You need to test in the same area of the extent of the DEM ESRI made available.
JinZhang
New Contributor III
Thank you ionara, we want to work with 1 meter and I did change
to
demLayer1 = "dem1m"
But still get the "The input profile line you requested falls outside of the data currently available in this service." I am wondering if 1 meter is not supported? I also noticed that our
While comparing our dem1m raster data to ESRI’s sample dem data, I noticed the attribute of the image under DEM data all have 0 as their Low value, however ours is  543.53. I am wondering if we have to update our dem raster data to change the low value to 0? Here is what our profile.mxd looks like:
Regards,
Jin
ionarawilson
New Contributor III
When do you get this error? After running the gp in a web service or during service publishing or when you run the gp in ArcMap? It is still complaining about the input not being in the same extent. I think the line file that you use to digitize might not be in the same projection. Make sure the spatial references are all the same. I dont think it has to do with low or high values. Notice on  my images, that all 3 files, the profileschema, the demboundary and the dem are in the same coordinate systems.
Here is the code that works for us. It is difficult for me to help since I cant see your code or the environment in your machine but I believe it is still a problem with the coordinate system. Good luck
Screenshot 2014-10-21 09.00.13.pngScreenshot 2014-10-21 08.51.48.pngScreenshot 2014-10-21 08.55.17.png
import os
import time
import arcpy
from arcpy.sa import *
    def __init__(self):
        .pyt file)."""
        self.alias = ""
    def __init__(self):
        # custom properties
        self.debug = True
        #arcpy.MakeFeatureLayer_management(r"D:\arcgisdata\Elevation\Profile\ProfileData\dembnd.gdb\demboundary", "demboundary")
        if False:
        profileSchm1 = r"D:\ArcGISData\Elevation\Profile\ProfileData\dembnd.gdb\profileschema"
        # DEM data layers
        if False:
                        "30":demLayer2,
                        "10":demLayer3}
        # DEM linear unit
            lun = 'feet'
            raise
            return
        uFactor = 1
            uFactor = 1
            uFactor = 0.01
            uFactor = 1
            uFactor = 0.1
            uFactor = 0.3048
            uFactor = 0.0254
            uFactor = 1000
            uFactor = 1609.344
            uFactor = 0.001
            uFactor = 1852
            uFactor = 1
            uFactor = 0.91440
        return uFactor
        # Footprint polygon
        resList = []
                                                in_line_features)
            for row in cursor:
        return resList
        countL = 0
        countV = 0
        totalLen = 0
        individualLen = []
        list_oid = []
        list_vert = []
            for row in cur:
                countL += 1
                totalLen += row[1]
        countV = 0
            for row in cur:
        return countV
        dem_res = []
        if in_len < 5000:
            dem_res = [30, 90]
        if in_len >= 15000:
            dem_res = [90]
        return dem_res
        res_list.sort()
            raise
        return res_list
            raise
        out_num = None
            out_num = 50
            out_num = 200
        return out_num
        if self.debug:
            if msg <> None:
            return
        elif inVal <= 0:
            raise
            return
            raise
            return
            raise
            return
            raise
        retVal = inSource
                retVal = d
                break
        return retVal
        try:
           # line_features_inputCS = os.path.join(r"in_memory", r"linetmpafterprj03")
            #route_temp = os.path.join(r"in_memory", "outroutetmp")
            #interp_line_temp = r"in_memory\interpouttmp"
            #out_vertices_temp = r"in_memory\verticestmp"
            #arcpy.env.workspace = "in_memory"
            line_features_inputCS = "in_memory\\" + "linetmpafterprj03"
            route_temp = "in_memory\\" + "outroutetmp"
            interp_line_temp = "in_memory\\" + "interpouttmp"
            out_vertices_temp = "in_memory\\" + "verticestmp"
            arcpy.env.workspace = "D:\\ArcGISData\\Elevation\\Profile\\ProfileData\\Scratch\\Scratch.gdb"
            dem = "D:\\ArcGISData\\Elevation\\Profile\\ProfileData\\demdata.gdb\\dem10m"
            arcpy.MakeRasterLayer_management(dem, "demlayer")
            arcpy.InterpolateShape_3d("demlayer",
                # project the line
                        for row in scur:
                            geo = row[0]
                            id_val = row[1]
                                for pnt in l1:
                                    x = pnt.X
                                    y = pnt.Y
                                    m = pnt.M
                                    z = pnt.Z
            else: # out to line
                # project the line
                # Add metadata info
                if inputIsInOcean:
                else:
                i = 0
                    for row in ucur:
                        i += 1
                        ucur.updateRow(row)
                if idFieldIsTemp:
        except:
            raise
                                 direction="Input",
                                 direction="Input",
                                 datatype="Field")
                                 direction="Input",
        dem_keys.sort()
                                 direction="Input",
                                 direction="Input",
                                 direction="Output",
        return params
        return True
        return
        return
        try:
            self.debug = False
          #  out_profile = os.path.join("in_memory", "profile1")
            out_profile = "D:\\ArcGISData\\Elevation\\Profile\\ProfileData\Scratch\\Scratch.gdb\\profile1"
            # Get input SR
            # project first
            polylines_after_prj = "in_memory\\" +  "inputlinetmp02"
                                "0", "PYTHON_9.3")
            if self.debug:
                fieldSp = 0
                fieldIsObjID = 1
                fieldSp = 1
                fieldIsObjID = 0
            # var for metering
            fieldSp = 1
            fieldIsObjID = 1
            samplingDistSp = 0
            if self.debug:
            if line_counts < 1:
                raise
                raise
                        raise
                        return
                        raise
                        return
                    needDensify = False
                    needWeed = False
                        out_num_vert = 50
                        needDensify = True
                        out_num_vert = 200
                        needDensify = True
                        needDensify = False
                        needDensify = False
                        needWeed = True
                    if needDensify:
                    if needWeed:
                else: # specified
                        raise
                        return
                    else:
                    raise
                    return
        except:
JinZhang
New Contributor III
Thank you ionara, I think i found the cause, our dem data uses feet as the unit, when run the profile script, I had to choose feet instead of meter(which is the default option), that seems the fix the error. Thank you again for your help and willingness to share your code.
Kind regards,
Jin
JinZhang
New Contributor III
Hi ionara,
I was able to publish the profile as a geo-processing service to our ArcGIS server. However when i run the profile service in ArcMap, I got the following error:
Error executing tool.: ERROR 000464: Cannot get exclusive schema lock.  Either being edited or in use by another application.
Failed to execute (CopyFeatures).
The input polyline feature is a shapefile located inside of a file geodatabase which is not used by any other application. I am not sure why I got the error saying there is a schema lock?
Jin
ionarawilson
New Contributor III
Hi Jin,
The answer is there, on the error message. Your data has a lock. You need to remove any locks from your data before running the tool.
JinZhang
New Contributor III
I found the problem, actually it is within the profile python code, we want to use 2m as the custom resolution, so i had the following:
        dem_res = []
        if in_len < 5000:
            dem_res = [2]
            dem_res = [2]
        if in_len >= 15000:
            dem_res = [2]
        return dem_res
After revert the above lines to
        dem_res = []
        if in_len < 5000:
            dem_res = [30, 90]
        if in_len >= 15000:
            dem_res = [90]
        return dem_res
Everything works fine.
Thank you,
Regards,
jin
