AnsweredAssumed Answered
Create Map Tile Package - Can't Set Required Description
Question asked by kbragg on Aug 28, 2014
Latest reply on Mar 8, 2016 by jskinner-esristaff
Hi all
In ArcGIS 10.2 I'm trying to use the GP tool "Create Map Tile Package" or similarly with ArcPy arcpy.CreateMapTilePackage_management()
in either case it errors with:
Map description property must be set
Failed to execute (CreateMapTilePackage).
I don't see how or where to set the description in either the tool or with the python syntax given:
CreateMapTilePackage_management (in_map, service_type, output_file, format_type, level_of_detail, {service_file}, {summary}, {tags})
This works just fine in ArcMap using the menu - File > Share As > Tile Package because I can enter the required description field in the dialog.
Here is the syntax I tried in ArcPy:
elevation_mxd = "C:\\sub\\elevation.mxd"
elevation_tpk = "C:\\sub\\elevation.tpk"
# Process: Create Map Tile Package
arcpy.CreateMapTilePackage_management(elevation_mxd, "ONLINE", elevation_tpk, "PNG", "3", "", "summary", "tag tag2")
Outcomes
