AnsweredAssumed Answered
ArcMap displays shp files with same projection in different place
Question asked by rioclaro on Aug 27, 2014
Latest reply on Aug 28, 2014 by rioclaro
Hello
I have two shp
(shp_05 and shp_10) files with same projection. Both files have to be in Lambert North Projection. However, when I open both shp files ArcMap display
each in different place. Also when I edit any shp file Arc Map displays: Spatial Reference does not match data frame
In ArcCatalog I have been trying to assign the Lambert North Projection but problem persist. I enclose image and shp files. I don’t understand why if both shp files are in same projection they are displayed in different place. How can I fix this?
I include Data Source of both shp files
Shp_05
Data Type:          Shapefile Feature Class
Shapefile:           D:\FN\Mapas\Shps\shp_05.shp
Geometry Type:              Polygon
Coordinates have Z
values:        No
Coordinates have measures:     No
Projected Coordinate
System:  Proyeccion_LambertNorte
Projection:         Lambert_Conformal_Conic
False_Easting:   500000.00000000
False_Northing:               271820.52200000
Central_Meridian:          -84.33333333
Standard_Parallel_1:     9.93333333
Standard_Parallel_2:     11.00000000
Latitude_Of_Origin:       10.46666667
Linear Unit:        Meter
Geographic Coordinate
System:              GCS_Clarke_1866
Datum:                D_Clarke_1866
Prime Meridian:              Greenwich
Angular Unit:     Degree
Shp_10
Shapefile:           D:\FN\Mapas\Shps\shp_10.shp
Coordinates have Z
values:        No
Coordinates have
measures:     No
Linear Unit:        Meter
Outcomes
