Network Analyst
2986
08-26-2014 07:20 AM
Data___Visualization_StudioDat
New Contributor III
I am creating a New Network Dataset through the Network Analyst tool.
When I get to the driving directions setting I click Yes but receive the following error.
"The direction settings are not read for the following reason:  A primary or alternate 'Name' field is not specified for an edge source.  File Name.  You can edit the settings or choose not to use directions."
I have tried to change a few options but still have had no luck.  Any thoughts on how I can get the directions to function properly?
Thanks!
TimSemmelhaack
New Contributor III
You have to fill in a value for the name field for each Network source in the Network Directions Properties
