Selection Tolerances in ArcGIS Online
3118
08-25-2014 02:13 PM
TomBell1
New Contributor III
How do you set selection tolerances in ArcGIS Online?  When I use a mobile device, it's nearly impossible to select a feature with my finger.  Is there a setting somewhere?
Thanks!
PaoloMilani1
New Contributor III
Hi Tom,
You say in a Web Application built from a model?
TomBell1
New Contributor III
Thank you, Paolo,
I'm using an Android device to open my web map.  I've tried:
  • opening the data as a web map (via the device's browser)
  • opening the data as a web map via the ArcGIS for Android App
  • opening data as several types of web mapping applications (the standard ones that Esri has)
In all cases, it's still near impossible to select any particular feature on an Android phone by using a finger.  You have to hit it like 10 times before it's selected, which makes the product really unusable as a practical tool.
I hope that makes sense.  I've no idea how to make the feature selection tolerances more forgiving so that the device can be used.
Thank you!
-Tom
PaoloMilani1
New Contributor III
Hi Tom,
Can you try to use this web Application on your device:
http://www.gruppoiit.lispa.it/summary-ricettive/
Tell me if it works well.
Bye
Paolo
Inviata dal mio Windows Phone
ToddHenry1
Tom,
Were you able to make any progress?  I'm having the same issue on my iPad.  It is ok with a feature service or a layer from a map service, but a Map Service is next to impossible.
