Feature services doesn't set right attribute values
1217
8
08-25-2014 12:46 AM
maximcouton
New Contributor III
I have published a feature  service on arcgis server, I am using ajax to push feature to.
I am pushing exactely this data :
var features = [
            "spatialReference" : {
              "wkid" : 2153
            "geometry" : {"x" : 266687.64720000332 , "y" : 6831744.5318000019},
            "attributes" : {
              "name_dept": "test dept",
The request result is a   success , it returns the record ID.
When I Query the service using the record ID  I get the feature but with   name_dept=null  instead of  name_dept = "test dept"
Any Idea ?
RainerSpitzer1
New Contributor III
Hi maxim,
can you please provide the schema of your feature Service? Maybe you created "name_dept" as Integer and not as String-Type...
maximcouton
New Contributor III
Hi Sir ,
He is the schema of name_dept
name_dept ( type: esriFieldTypeString , alias: name_dept , editable: true , nullable: true , length: 30 )
RainerSpitzer1
New Contributor III
if you send your example as written above, try to remove the comma behind "test dept"
var features = [ {
          "wkid" : 2153
     "geometry" : {
     "attributes" : {
Can you add the feature correctly by using the rest-interface of your featureservice?
maximcouton
New Contributor III
I removed the comma but still not working.
It not working neither in the rest interface of arcgis neither in my code.
When I make a post I get the sucess :
{"addResults": [{
"objectId": 133,
"success": true
But When I query I get :
"objectIdFieldName": "objectid",
"globalIdFieldName": "",
"fields": [
  "name": "name_dept",
  "alias": "name_dept",
  "type": "esriFieldTypeString",
  "length": 30
"features": [
  "attributes": {
  "name_dept": null
So It found the record but does't set the geomtry.
I used ArcMap the view my database , the feature I posted is not inserted in the database.
RainerSpitzer1
New Contributor III
Hmm,
maybe something with your featureservice isn't set up right. I tried your example using the rest-interface and it worked very well. You can try this, if you want:
http://services1.arcgis.com/vgQLECcJ4FMJQl0M/arcgis/rest/services/brazil_solar_global_10km/FeatureSe...
Paste this into the Box:
              "wkid" : 2153
            "attributes" : {
              "CEL": "test dept"
You should start getting this work with your service first. Remember that the fieldnames are case-sensitive.
maximcouton
New Contributor III
Hi Sir,
Exactely some thing is wrong with the feature service I am using .
I just wan to  ask you a favor. Can I use your service istead  to do my tests ?
I am developping an API for  that. So I need to use a Feature Service.
RainerSpitzer1
New Contributor III
Hi maxim,
unfortunately it is not possible to use this Featureservice for your development. But I can help you creating your own FeatureService in your own Developer subscription, if you want.
maximcouton
New Contributor III
If That is ok sir, want the service also to return some fields. Because currently no field is returned.
Thanks a Lot.
