From Decimal degrees to meter
15706
7
08-24-2014 06:28 AM
KasperSmith_Larsen
Hey Guys
I have a data set Air mass trajectories (excel file) with a lot of points given in decimal degrees. I have plotted the trajectories in Arcmap but I need to know the distance between them. They span more or less from equator to Greenland so there is the issue of different E/W distances.
Regards Kasper
BruceHarold
If you do not have Desktop Advanced and the Near GP tool then provided you can deal with 0.5% error then the Haversine formula might be suitable.
Or Vincenty if you want to get fancy.
DanPatterson_Retired
I don't work with data covering such a large area, but I would suggest km...in any event you probably want the geodesic distances which have new options in 10.2.1 perhaps using the Near tool
stefanstamenov
Occasional Contributor III
stefanstamenov
This must work, though I never used it
Latitude/Longitude Distance Calculator
BruceHarold
KasperSmith_Larsen
Thanks for your answers.
I have tried using the Haversine formula in excel but I can’t get the right distance. I have calculated the following parameter:
R = earth’s radius (mean radius = 6,371km)
Δlat = lat2− lat1
Δlong = long2− long1
a = sin²(Δlat/2) + cos(lat1)*cos(lat2)*sin²(Δlong/2)
c = 2*atan2(√a, √(1−a))
d = R*c (distance)
As described at http://www.ig.utexas.edu/outreach/googleearth/latlong.html
It says on the web-site that angles need to be in radians and I tried with radians calculated from both decimal degrees and degrees, minutes, seconds.
BruceHarold
KasperSmith_Larsen
Now I got the Haversine fomula to work so problem solved
Thanks to all of you for your input they really helped.
