Passing st_geometry column as argument in pl/sql procedure
2484
08-22-2014 05:58 AM
StephenCzajkowski
Hi   Using  SDE 10.1 in Oracle with ST_Geometry Table..   Am writing  a pl/sql procedure to do a st_intersects of all items of one table against one feature of another.  The procedure takes as arguments the fields of the single feature:
create or replace PROCEDURE INTERSECT_WITH_TO_LINKSET_FCS
  CLUS IN VARCHAR2,
  FR_LNKS IN VARCHAR2,
  FR_CLLI IN VARCHAR2,
  FR_CABLEID IN VARCHAR2,
  FR_CAB_UNIT_NUM IN VARCHAR2,
  FR_ACLLI IN VARCHAR2,
  FR_ZCLLI IN VARCHAR2,
  FR_SA_ID IN VARCHAR2,
  FR_SHAPE IN SDE.ST_GEOMETRY,
  LINKSET_FC IN VARCHAR2
) AS
When I try to compile this an error is generated that ST_Geometry must be declared.  It must be some type of permissions thing because ST_Geomtery is the TYPE for the SHAPE field in the featureclass.   Anyone's thoughts would be much appreciated.  I have tried to write "FR_SHAPE" as ST_Geometry, SDE.ST_Gemoetry, etc.  No variations compile.
Steve Czajkowski
Tags (3)
TeroRönkkö
Does it work if you create that pl/sql procedure as SDE user? If it does then it might be type publishing limitation
ForrestJones
Hi Steve, as Tero suggests, see if it works with the sde user. It could be a privileges issue for the user you are trying to create the procedure with. You should also be able to run describe sde.st_geometry.
