AnsweredAssumed Answered
How do I ZOOM into a selected value from a combox and create a POPUP to show info in ArcGIS API for JavaScript?
Question asked by wootiewoot on Aug 21, 2014
Latest reply on Jun 8, 2015 by satyanarayana_narmala
Hi all,
I really need your help! I am fairly new to the coding world, especially ArcGIS API for JavaScript. Let me get straight to the point. I am trying to create a web-based map application that contains information of Counties and Cities in California. Ultimately, when I select a particular jurisdiction, the map will automatically zoom into that jurisdiction and highlights its boundary. I also want to develop a popup window that illustrates some information of that selected jurisdiction.
I have been "googling" for a solution online and this is what I came up with so far. I got the list to populate but it doesn't zoom into the jurisdiction when I select it. Please look at my code below:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Populate dropdown list with unique values</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style type="text/css">body,html,#main{margin:0;padding:0;height:100%;width:100%;}</style>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
    var map;
var resizeTimer;
      require([
      "esri/map", "esri/tasks/query", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/form/ComboBox", "dojo/data/ItemFileReadStore","dojo/store/Memory", "dojo/on", "dojo/domReady!"],
      function(Map, query, parser, BorderContainer, ContentPane, ComboBox, ItemFileReadStore, Memory, on) {
        parser.parse();
        map = new Map("map", {
            basemap: "topo",
            //center: [-122.45, 37.75], // longitude, latitude
            center : [-120.676665, 37.306837],
            zoom: 6
        var queryTask = new esri.tasks.QueryTask("http://services.arcgis.com/IARhjUVNlIMumZL3/ArcGIS/rest/services/OTS_MAP/FeatureServer/1");
        //Define query parameters
        var query = new esri.tasks.Query();
        query.outFields = ["NAME", "POP", "DVMT", "FATAL_OTS"];
        query.returnGeometry = true;
        query.where  = "NAME <> ''"
        queryTask.execute(query,populateList);
        //var initialExtent = new esri.geometry.Extent(-85.915,38.105,-85.52,38.33,
          //      new esri.SpatialReference({wkid:4326}) );
       // map = new esri.Map("map", {extent:initialExtent});
        //Create tiled and dynamic map services and add to the map - for the dynamic service set the transparency
        //and provide an id so we can access it later
        map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"));
        map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgis.com/IARhjUVNlIMumZL3/ArcGIS/rest/services/CPP4OTS_MAP/MapServer",
                {"opacity":.4,"id":"dynamic"}));
      function populateList(results) {
        //initialize InfoTemplate
            infoTemplate = new esri.InfoTemplate("${NAME}", "County : ${NAME}<br/> Population : ${POP}<br/> Daily VMT : ${DVMT} <br/> Fatal OTS : ${FATAL_OTS}");
        //create symbol for selected features
            symbol = new esri.symbol.SimpleMarkerSymbol();
            symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
            symbol.setSize(10);
            symbol.setColor(new dojo.Color([255, 255, 0, 0.5]));
        //Populate the dropdown list box with unique values
        var county;
        var values = [];
        var testVals={};
        //Add option to display all zoning types to the dropdown list
        values.push({name:"ALL"})
        var features = results.features;
        dojo.forEach (features, function(feature) {
          county = feature.attributes.NAME;
          if (!testVals[county]) {
            testVals[county] = true;
            values.push({name:county});
        var dataItems = {
               identifier: 'name',
               label: 'name',
               items: values
        var store = new dojo.store.Memory({data:dataItems});
        dijit.byId("mySelect").store = store;
        //remove all graphics on the maps graphics layer
        map.graphics.clear();
        //Performance enhancer - assign featureSet array to a single variable.
        var resultFeatures = results.features;
        //Loop through each feature returned
        for (var i = 0, il = resultFeatures.length; i < il; i++) {
                //Get the current feature from the featureSet.
                //Feature is a graphic
                var graphic = resultFeatures[i];
                graphic.setSymbol(symbol);
                //Set the infoTemplate.
                graphic.setInfoTemplate(infoTemplate);
                //Add graphic to the map graphics layer.
                map.graphics.add(graphic);
                // This takes the graphics array you get back from your query and
                // gets the overall extent for them. Make sure return geometry is set to
                // true in your query.
                var extent = esri.graphicsExtent(results.features);
                // Use that to set the extent, 1.5 is something I use in my app, but play with
                // it to find a setting you like, setting the second parameter to true will get you an extend
                // that is at the closest level of your cached service.
                map.setExtent(extent.expand(1.7), true);
      // this replaces your applyLayerDef() function
      dijit.byId("mySelect").on("change", function () {
        //Filter the layer to display only the selected zoning types
        var county = dijit.byId("mySelect").value;
        if (county !== 'ALL') {
          var layerDefs = [];
          layerDefs[2] = "NAME = " + "'" + county + "'";
          layerDefs.visibleLayers = [2];
          map.getLayer("dynamic").setLayerDefinitions(layerDefs);
        else {
          map.getLayer("dynamic").setDefaultLayerDefinitions();
      function resizeMap() {
        //Handle browser resize
        clearTimeout(resizeTimer);
        resizeTimer = setTimeout(function() {
          map.resize();
          map.reposition();
        }, 800);
    </script>
  </head>
  <body class="claro">
    <div id="main"
            dojotype="dijit.layout.BorderContainer"
            design="headline"
            gutters="true">
      <div id="header"
             dojotype="dijit.layout.ContentPane"
             region="top"
             style="height:25px;">
        <select id="mySelect"
             dojotype="dijit.form.ComboBox"
             style="width:300px;font-size:18px;"
             autoComplete="true"
             forceValidOption="false"
             value="Select Zoning Type"></select>
      </div>
      <div id="map"
             region="center"
             style="border:1px solid #000;margin:5px">
      </div>
    </div>
  </body>
</html>
Outcomes
