I need a sample to perform select search like this website:
When you select the dropdown menu, it will shows your selection option. When you select it then it will zoom to the location. I didn't find any ESRI samples for it.
Thanks.
Solved! Go to Solution.
May Jeff,
You are not going to find samples for everything you want to do. This is just a simple FindTask that is being executed and then zooming to the results. There are plenty of samples for that functionality.
Thank you for your sample.
