I’ve tried this set(material.reflectivity, 0.1) That don’t give me anything, no matter what value I use. Is it possible to get reflection inside a webscene?
hi ..
reflection works best in conjunction with the other specularity settings.
and 0.1 is almost nothing. try a higher value..
check the values in the instance city example. they may be extreme, but get you going.
matt
Thank you Matt. I did try any reflectivity amount. But for some reason it worked after I restarted my machine. It was probably something with my graphic card, since it was running very strange.
Hmm. okay.
Maybe also try to make sure you're working on the latest driver.
Kind greetings !
Matt
