compare two fields if they 'are equal or not, in the field calculator
2923
08-20-2014 03:56 PM
GustavoCordero
New Contributor III
I have two "A" fields and "B" and I want to use the field calculator in the "C" field to determine if they are equal
put 1 if they are equal and 0 if they  not
  example
    A | B | C |
     3 | 3 | 1 |
     5 | 7 | 0 |
I found this scrip
but it only works in python window
import arcpy
fc = R 'c: \ path \ to \ your \ fc'
with arcpy.da.UpdateCursor (fc, ["FIELD1", "FIELD2", "FIELD3"]) as cursor:
     for row in cursor:
         if row [0] == row [1]:
             row [2] = 1
         else:
             row [2] = 0
         cursor.updateRow (row)
"I want to use the field calculator"
  or as a tool for modelbuidel where "fc = R'c: \ path \ to \ your \ fc '         can be a Shapefile imput
RiyasDeen
Occasional Contributor III
Hi Gustavo,
Try below:
Script:
def isEqual(x,y):
if x == y:
  return 1
else:
  return 0
DarrenWiens2
MVP Honored Contributor
Or in VBScript:
GustavoCordero
New Contributor III
thank you very much for your answer
DanPatterson_Retired
Of course both meant to point out that you would replace their field names with yours...in the case of python you need to remember that field names are enclosed in ! marks whereas in VBscript they are surrounded by square brackets.  Also, in python, the equality check is == whereas in VBscript a single = will suffice.
