issues with esri proxy
2003
6
08-20-2014 02:55 AM
maximcouton
New Contributor III
I have some issues when using esri proxy Java Version,
Releases · Esri/resource-proxy · GitHub
After deploying it on tomcat , it still telling me that proxy.config file is not readable or it doesn't exist.
I am sure that the file exist at this location,
any idea ?
Tags (1)
maximcouton
New Contributor III
In fact ,
I have resolved the problem by putting  the URL of page requesting the service inside the  proxy.config file
using option allowedReferers. allowedReferers="*"  is not working for me, I had to replace * by my page url.
Maxim,
Thanks you guys trying helping me.
by Anonymous User
Not applicable
Hi Maxim,
Did you follow the instructions of the README.md file?
What do you receive when you enter the following url?:
http://[yourmachine]/Java/proxy.jsp?http://services.arcgisonline.com/ArcGIS/rest/services/?f=pjson
Richard
maximcouton
New Contributor III
When I enter  http://localhost:8080/Java/proxy.jsp?http://services.arcgisonline.com/ArcGIS/rest/services/?f=pjson
It says :
The proxy.config file does not exist at application root, or is not readable.
maximcouton
New Contributor III
Hi,Hi,
it is now working  with tomcat, when typing the folowwing URL in the browser it forwads me the site
http://localhost:8080/Java/proxy.jsp?http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty...
But  when using the API , it tells me that the ressource is forbidden (403 errror code), here is my config
esriConfig.defaults.io.proxyUrl = "http://localhost:8080/Java/proxy.jsp"
var wmsLayer = new WMSLayer("http://sampleserver1.arcgisonline.com/ArcGIS/services/Specialty/ESRI_StateCityHighway_USA/MapServer/...", {
            format: "png",
            visibleLayers: [2]
map.addLayer(wmsLayer);
Any idea ?
OwenEarley
Occasional Contributor III
Check that you have allowed the ESRI sample server URL in your proxy configuration file. The following example allows access to 2 servers:
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
                logFile="proxy_log.log"
                logLevel="INFO"
                mustMatch="true">
  <serverUrls>
    <serverUrl url="http://services.arcgisonline.com" matchAll="true"/>
    <serverUrl url="http://sampleserver1.arcgisonline.com" matchAll="true"/>
  </serverUrls>
</ProxyConfig>
Trying to access any server not in this list should result in a 403 error from your proxy.
Owen
Spatial XP
maximcouton
New Contributor III
Hi thanks ,
My proxy.config is configured like you suggested, but still doesn't work. still  forbiden acces to
when executing JavaScript code.
But when I copy past this url to the browser , it redirect me to the site.
Any idea why it is not working in a javascript code ? Thanks
He is my code in JS:
esriConfig.defaults.io.proxyUrl = "http://localhost:8080/Java/proxy.jsp";
           map = new Map("map", {
             basemap: "streets",
             center: [-98, 37],
             zoom: 5
            format: "png",
            visibleLayers: [2]
maximcouton
New Contributor III
In fact ,
Maxim,
