I want when i click on the grid, then drawing a symbol on the map, but my code does not work
2562
08-20-2014 05:03 AM
lasinh
New Contributor III
require([
    "esri/map",
      "dojo/ready",
      "dgrid/OnDemandGrid",
       "dojo/dom",
       "dojo/on",
       "esri/graphic",
       "esri/geometry/Point",
      "dgrid/Selection",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/dom-style",
      "dijit/registry",
      "esri/tasks/query",
      "esri/Color",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/InfoTemplate",
      "dojo/_base/Color",
       "esri/renderers/SimpleRenderer",
      "esri/layers/FeatureLayer",
      "esri/symbols/SimpleFillSymbol",
      "esri/symbols/SimpleLineSymbol",
      "esri/tasks/QueryTask",
      "dojo/_base/declare",
      "dojo/number",
      "dojo/on",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane"
      ], function (
      map,
        ready,
        Grid,
        dom,
        on,
        graphic,
        Point,
        Selection,
        Memory,
        array,
        domStyle,
        registry,
        Query,
        Color,
        SimpleMarkerSymbol,
        InfoTemplate,
        Color1,
        SimpleRenderer,
        FeatureLayer,
        SimpleFillSymbol,
        SimpleLineSymbol,
        QueryTask,
        declare,
        dojoNum,
        on,
        parser
          ready(function () {
              parser.parse();
              // create the dgrid
              window.grid = new (declare([Grid, Selection]))({
                  // use Infinity so that all data is available in the grid
                  bufferRows: Infinity,
                  columns: {
                      "id": { "label": "STT" },
                      //                      "maso": { "label": "Mã", "formatter": dojoNum.format },
                      "ten": { "label": "Tên" },
                      "diachi": { "label": "địa chỉ" }
                      //                      "dientich": { "label": "Diện tích", "formatter": dojoNum.format }
              }, "timkiem");
              // add a click listener on the ID column
              grid.on(".field-id:click", selectState);
              window.map = map;
                       var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://192.166.3.252:6080/arcgis/rest/services/NENCHUNG/Nen_chung1/MapServer");
                      myMap.addLayer(layer);
              window.statesUrl = "http://192.166.3.252:6080/arcgis/rest/services/NENCHUNG/Nen_chung1/MapServer/2";
              window.outFields = ["OBJECTID", "ten", "diaChi"];
              queryTask1 = new QueryTask(window.statesUrl);
              //initialize query
              query1 = new esri.tasks.Query();
              query1.returnGeometry = true;
              query1.outFields = window.outFields;
              //initialize InfoTemplate
              infoTemplate1 = new InfoTemplate("${OBJECTID}", "Name : ${OBJECTID}<br/> State : ${ten}<br />Population : ${diaChi}");
//              create symbol for selected features
              symbol1 = new SimpleMarkerSymbol();
              symbol1.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
              symbol1.setSize(80);
              symbol1.setColor(new Color([255, 255, 0, 1]));
              var fl = new FeatureLayer(window.statesUrl, {
                  mode: 1, // ONDEMAND, could also use FeatureLayer.MODE_ONDEMAND
                  outFields: window.outFields
              fl.on("load", function () {
                  fl.maxScale = 0; // show the states layer at all scales
              //change cursor to indicate features are click-able
              fl.on("mouse-over", function () {
                  myMap.setMapCursor("pointer");
              fl.on("mouse-out", function () {
                  myMap.setMapCursor("default");
              myMap.addLayer(fl);
              myMap.on("layers-add-result", populateGrid(Memory));
              function populateGrid(Memory) {
                  var qt = new QueryTask(window.statesUrl);
                  //                  TENHUYEN LIKE'%" + dom.byId("search-text").value + "%'
                  var query = new Query();
                  query.where = "ten LIKE'%" + dom.byId("search-text").value + "%'";
                  query.returnGeometry = false;
                  query.outFields = window.outFields;
                  qt.execute(query, function (results) {
                      var data = array.map(results.features, function (feature) {
                          return {
                              // property names used here match those used when creating the dgrid
                              "id": feature.attributes[window.outFields[0]],
                              "ten": feature.attributes[window.outFields[1]],
                              "diachi": feature.attributes[window.outFields[2]]
                              //                              "dientich": feature.attributes[window.outFields[3]]
                      var memStore = new Memory({ data: data });
                      window.grid.set("store", memStore);
              // fires when a row in the dgrid is clicked
              function selectState(e) {
                  query1.where = "1=1";
                  //execute query
                  queryTask1.execute(query1, showResults);
              function showResults(featureSet) {
                  //remove all graphics on the maps graphics layer
                  myMap.graphics.clear();
                  //Performance enhancer - assign featureSet array to a single variable.
                  var resultFeatures = featureSet.features;
                  //Loop through each feature returned
                  for (var i = 0, il = resultFeatures.length; i < il; i++) {
                      //Get the current feature from the featureSet.
                      //Feature is a graphic
                      var graphic = resultFeatures;
                      graphic.setSymbol(symbol1);
                      //Set the infoTemplate.
                   graphic.setInfoTemplate(infoTemplate1);
                      //Add graphic to the map graphics layer.
                      myMap.graphics.add(graphic);
KenBuja
MVP Esteemed Contributor
A few point on your code. You have "dojo/on" twice in your require statement (and twice in your function arguments).
Where are you initializing the map?
window.map = map;
And where did myMap come from?
Take a closer look at the dGrid sample where some of this code came from.
KenBuja
window.map = map;
lasinh
New Contributor III
var myMap =new map("mydiv");
myMap.addlayer(fl);
lasinh
New Contributor III
when clicked line on dgrid, symbol is not shown at map
