Can't register SQL Server with ArcGIS Server 10.2.2
3437
6
08-18-2014 05:33 PM
JeffJacobson
Occasional Contributor III
When I try to register a database by importing a .sde file through the server manager web application, I get the following (not at all helpful) error message:
[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object]
Why is this the import failing?
AsrujitSengupta
Regular Contributor III
Have you tried registering the database from ArcCatalog? Does it have the same issue?
** Please provide configuration details (example: ArcGIS Desktop 10.2.2, ArcGIS Server 10.2.2, SQL Server 2008 R2\Oracle 11.2.0.3, etc)
ModyBuchbinder
Hi
Jeff
Are
the server and desktop that created the sde file on the same machine?
If
the sde file include windows authentication you must make sure the user that
own ArcSOC.exe have database access.
You
might need to install the rdbms access files – you can download them from
My.Esri.com
Have
fun
Mody
AsrujitSengupta
JeffJacobson
Asrujit SenGupta, it worked when I did it from ArcCatalog. Weird.
DarylHochhalter
I am having the same issue as Jeff. I have an sde connection file that works fine in Catalog, but I can't use it to register the database with ArcGIS server 10.4, we are using SQL Server 2014, on Windows Server 2012 R2.
MichelyTavares
My case I have a PostgreSQL database and try to register with ArcGIS Server database, he acknowledges, makes the connection , but the following error appears :. " The set of binding properties missing a required property or the property value was not recognized invalid database name " Can anyone help me ?
The database and arcgis desktop is on my machine and the arcgis server is on another machine.
Configuração:
Postgresql 9.3.10
Arcgis Server 10.3
Arcgis Desktop 10.3
by Anonymous User
Not applicable
You can also use same connection file in ArcGIS server manager to register database with ArcGIS server
