Co-ordinate trouble in ArcMap
3963
08-15-2014 06:22 AM
AmySteel
I have added a series of Co-ordinates into ArcMap from an excel workbook and the import fine without any trouble, however when added a basemap check the were in the correct place, they are appearing in the middle of the sea off the coast of Newquay when they should be the other end of the country in Orkney off the coast of Scotland. The co-ordinates were added as british national grid so I projected them to WGS  to see if the would be the problem but they just move about an inch to the left so no luck.. however when you input the co-ordinates into google earth they are appearing in the right place?
Any help would be much appreciated!
RiyasDeen
Occasional Contributor III
Make sure you are specifying the correct coordiate system when adding your coordinates to your map, if XY data is the first layer on the map then the layer will be added with undefined coordinate system.
If your base map and your coordinates are in different coordinate system, if you don't explicitly specify the coordinate system when adding map, arcmap will not be able to correctly project on fly.
RiyasDeen
MelitaKennedy
Esri Notable Contributor
If Riyas Deen​ 's answer doesn't help, please post an example coordinate pair from your Excel worksheet. My guess is that the coordinates aren't in BNG, but are latitude-longitude.
Melita
SimonKettle
