Applying lyr symbology to raster
2231
08-14-2014 07:01 AM
JoshObrecht
I have a lyr file that was created off of a raster using unique values. I would like to apply this to another raster. When I use the lyr file however, all cells show as black. They should be varied. Through testing, it's not that there are too many unique values or that it is being symbolized by the "all other values" color. Has anyone else run into this situation?
IanMcGovern
What file type are you using for your Raster? I've had TIFs and JPGs self destruct like this upon reloading in older versions of Desktop. Exporting to a new file type worked for me in the past.
JoshObrecht
It is a file geodatabase raster dataset
IanMcGovern
Are the two rasters of the same pixel type and depth (I.e. unsigned 8 bit)?
