Trouble with selecting features with both ISelectionSet and IFeatureSelection
797
08-11-2010 12:47 PM
JenniferHird
I am a novice with ArcObjects programming (VBA/VB6). I am trying to select features from a point feature class that intersect with a particular polygon in a polygon feature class. I have tried using both the ISelectionSet interface (with the pFeatureClass.Select method), and the IFeatureSelection interface (the SelectFeatures method). I do not run into any compile or run-time errors, but in both cases the pSelectionSet.Count property returns a '0' at the end of the code. I know that this number should not be '0' (it should be upwards of 100 for some of my File Geodatabses). Why does it return a SelectionSet with 0 features in it?
Here is the code in which I try to use ISelectionSet:
'pPtFClass is a point feature class
'pPplotFClass is a polygon feature class
'The above are both within the same FileGeodatabase
'Set up a cursor to move through the features in the polygon feature class
Dim pPPlotFields As IFields
Set pPPlotFields = pPplotFClass.Fields
Dim intPosSUBTYPEField As Integer
intPosSUBTYPEField = pPPlotFields.FindField("SUBTYPE")
Dim intPosOBJECTIDField As Integer
intPosOBJECTIDField = pPPlotFields.FindField("OBJECTID")
Dim pPPlotFeatCursor As IFeatureCursor
Set pPPlotFeatCursor = pPplotFClass.Update(Nothing, True)
If pPPlotFeat Is Nothing Then
MsgBox "No features in abmi_pplot feature class." & vbCrLf & "Exiting subroutine."
Exit Function
End If
Do Until pPPlotFeat Is Nothing
'Select all point features that intersect the polygon whose SUBTYPE = 2
If pPPlotFeat.Value(intPosSUBTYPEField) = 2 Then
Dim pPplotIndivFeat As IFeature
Set pPplotIndivFeat = pPplotFClass.GetFeature(pPPlotFeat.Value(intPosOBJECTIDField))
Dim pQueryGeometry As IGeometry
Set pQueryGeometry = pPplotIndivFeat.Shape
Dim pSpatialFilter As ISpatialFilter
Set pSpatialFilter = New SpatialFilter
With pSpatialFilter
Set .Geometry = pQueryGeometry
.GeometryField = pPtFClass.ShapeFieldName
.SpatialRel = esriSpatialRelIntersects
End With
Dim pScratchWSFactory As IScratchWorkspaceFactory
Set pScratchWSFactory = New ScratchWorkspaceFactory
Dim pScratchWS As IWorkspace
Set pScratchWS = pScratchWSFactory.DefaultScratchWorkspace
Dim pInCoreSelSet As ISelectionSet
Set pInCoreSelSet = pPtFClass.Select(pSpatialFilter, _
esriSelectionTypeIDSet, esriSelectionOptionNormal, pScratchWS)
MsgBox "Number of point features in pInCoreSelSet: " & pInCoreSelSet.Count '*<<<<<<<<<<*
End if
Set pPPlotFeat = pPPlotFeatCursor.NextFeature
Loop
Alternatively, here is the code in which I try to use IFeatureSelection:
MsgBox "No features in abmi_pplot feature class." & vbCrLf & _
Exit Function
End If
Dim pCorePtFLayer As IFeatureLayer
Set pCorePtFLayer = New FeatureLayer
Set pCorePtFLayer.FeatureClass = pPtFClass
Dim pPtCoreFeatSel As IFeatureSelection
Set pPtCoreFeatSel = pCorePtFLayer
With pSpatialFilter
End With
pPtCoreFeatSel.SelectFeatures pSpatialFilter, esriSelectionResultAdd, False
End if
Loop
Both of these return a '0' on for the .Count method (see lines with '*<<<<<<<<<<*).
I very much appreciate any advice or suggestions! Thank you!
Regards,
Jen Hird
JeffMatson
Occasional Contributor III
Maybe try using IFeatureSelection.Add instead? Here is a sample that might help (currently just uses the top map layers, layer 0 is the point layer and layer 1 is the polygon layer)
Public Sub SelectPoints()
    Dim pFeature As IFeature
    Dim pFLayer_point As IFeatureLayer
    Dim pFLayer_poly As IFeatureLayer
    Dim pFSelection_point As IFeatureSelection
    Dim pFSelection_poly As IFeatureSelection
    Dim pSelectionSet As ISelectionSet
    Dim pFClass_poly As IFeatureClass
    Dim pFCursor As IFeatureCursor
    Dim pResult As IFeatureCursor
    Dim pResFeat As IFeature
    Dim pGeometry As IGeometry
    Dim pMxDocument As IMxDocument
    Dim pActiveView As IActiveView
    Dim pmap As IMap
    Dim pTOC As IContentsView
    Set pMxDocument = Application.Document
    Set pActiveView = pMxDocument.ActiveView
    Set pmap = pMxDocument.FocusMap
    Set pFLayer_point = pmap.Layer(0)
    Set pFLayer_poly = pmap.Layer(1)
    Set pFClass_poly = pFLayer_poly.FeatureClass
    Set pFSelection_poly = pFLayer_poly
    Set pFCursor = pFClass_poly.Search(Nothing, False)
    Set pFeature = pFCursor.NextFeature
    While Not pFeature Is Nothing
        Set pGeometry = pFeature.Shape
        With pSpatialFilter
            Set pSpatialFilter.Geometry = pGeometry
            .GeometryField = pFClass_poly.ShapeFieldName 'not necessary
            .SpatialRel = esriSpatialRelContains
        End With
        Set pResult = pFLayer_point.Search(pSpatialFilter, False)
        Set pFSelection_point = pFLayer_point
        Set pResFeat = pResult.NextFeature
        Do Until pResFeat Is Nothing
            pFSelection_point.Add pResFeat
        Loop
    Wend
    pActiveView.Refresh
    'refresh the selection tab of the TOC (item #2)
    Set pTOC = pMxDocument.ContentsView(2)
    pTOC.Refresh 0 'not sure why this needs an argument, #s 0-4 provide same result?
End Sub
JenniferHird
Hi Jeff,
Thank you so much for the quick response, and the suggestion!  I actually found my mistake - someone changed the meaning of the "SUBTYPE" attribute in the polygon layer in the newer version of the data sets I am working with, so it should actually have been a 1 instead of a 2.  In other words, I was using the wrong polygon for the spatial query (one that did not have any point features contained within it).  Once I changed this, the code worked.  So it was a logical error on my part.  It's funny how you find the answer yourself after you have decided to admit defeat and ask for help 🙂
Thanks again for the help!  I've found these forums to be very informative many, many times, and it is all due to people like you.
Regards,
Jen
JeffMatson
Nice catch - the Subtype thing was going to be my second question...now you probably can't call yourself a novice anymore 🙂
