Web Appbuilder Beta Clustering
5572
08-12-2014 06:37 AM
Mtclimber03
Does anyone know if there is a way to use clustering for points with the web appbuilder? I'm looking for an output similar to that of how clustering can be accomplished with the .JS API or the Silverlight viewer. I thought this might be baked into AGOL somewhere but have not seen that as an option either.
JasonHine
Web AppBuilder currently supports point clustering two ways:
  • You can make a Web Map with a point layer, and configure clustering on the point layer. The Web Map can be used by Web AppBuilder.
  • You can add the Info Summary widget, and use it to cluster a point layer.
JasonHine
