I want to have my results show up on left pane when identify a parcel. Here is my JSFiddle: Edit fiddle - JSFiddle
Can someone tell me how come I can't get the content to show up inside left pane?
Thank you.
Solved! Go to Solution.
May Jeff,
Here the code cleaned up and working as desired.
Thank you Robert. That's what I am look for. I want to ask you a question before I mark this discussion so you can see it. Can the left pane's content show "Zoom to" link like infoWindow?
May Jeff,
Not unless you add that feature programmatically. The side info window is just a ContentPane div that just displays the text from the content variable.
Thank you Robert!
