AnsweredAssumed Answered
Entire field populating with same value
Question asked by wtgeographer on Aug 8, 2014
Latest reply on Aug 8, 2014 by wtgeographer
I am attempting to search directories and sub directories for file in 'name'  and return full file path of found file in a new field.  When I print the value of variable 'string' it prints the desired results However after the script runs the field is populated with a single value instead of unique values for each subsequent row.  Can anyone tell me why this is?
# Set local variable
source = 'R:\\'
fc = "I14__ATTACH_TEST"
field = "ATT_NAME"
addfieldName = "fullPath"
fieldLength = 200
# Add field
arcpy.AddField_management(fc, addfieldName, "TEXT", "", "", fieldLength)
### Attempting to search directories and sub directories for file in 'name'
###    and return full file path of found file (name)
sc = arcpy.SearchCursor(fc)
names = []
for scrow in sc:
    names.append(scrow.getValue(field))
for root, dirnames, filenames in os.walk(source):
        for filename in filenames:
            if filename in names:
                string = os.path.join(root, filename)
                cursor = arcpy.UpdateCursor(fc)
                row = cursor.next()
                while row:
                    # field2 will be equal to field1 multiplied by 3.0
                    row.setValue(addfieldName, string)
                    cursor.updateRow(row)
                    row = cursor.next()
Outcomes
