UNABLE TO CLIP THE EXTENT, SPATIAL REFERENCE IS MISSING?
2731
08-08-2014 05:45 PM
ChuckKha
New Contributor III
Hey Everyone,
I keep getting this error: "Unable to clip the extent, spatial reference is missing" everytime that I try to publish my tile on AGOL. My original file before I packaged it in Arcmap by using the Export Tile Package tool and uploaded it to AGOL by using the Share Package tool, had a projection defined so I'm not sure why I'm getting this error. Here is a screenshot of the problem.
The file size is approximately 3 GB. Is there a work around for this?
JakeSkinner
Esri Esteemed Contributor
Hi Chuck,
Click on the URL under 'Map Contents'.  This will show if the service has a spatial reference or not.  Ex:
ChuckKha
New Contributor III
Hey Jake,
This is what I have when I click that URL. It shows on the bottom that there is a spatial reference. Any idea why I'd be getting the error?
Spatial Reference:
103007
Single Fused Map Cache: true
Tile Info:
  • Height: 256
  • Width: 256
  • DPI: 96
  • Levels of Detail: (# Levels: 21)
  • Format: PNG
  • Compression Quality: 0
  • Origin:
      • X: -1.176089E8
      • Y: 1.564597E8
  • Spatial Reference:
    103007
    PROJCS["NAD_1983_2011_StatePlane_California_V_FIPS_0405_Ft_US",GEOGCS["GCS_NAD_1983_2011",DATUM["D_NAD_1983_2011",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",6561666.666666666],PARAMETER["False_Northing",1640416.666666667],PARAMETER["Central_Meridian",-118.0],PARAMETER["Standard_Parallel_1",34.03333333333333],PARAMETER["Standard_Parallel_2",35.46666666666667],PARAMETER["Latitude_Of_Origin",33.5],UNIT["Foot_US",0.3048006096012192],AUTHORITY["ESRI",103007]
StefKoroblitsas
Did this ever get resolved? i am currently experiencing the same problem
KellyGerrow
Esri Frequent Contributor
Is your spatial reference set in the Rest endpoint? I would suggest posting about your specific issue as the original post is quite old. Can you share your tile package?
-Kelly
