How do I subscribe to INetworkLoaderProgress using .NET?
788
08-09-2014 07:16 AM
KirkKuykendall
Occasional Contributor III
I'm using INetworkLoader3 to build a geometric network.  I'd like to show progress on the UI.
It appears INetworkLoaderProgress is designed for this purpose, but I don't see how to use it.
Also I see INetworkLoaderProgress_Sinkhelper class (not interface), but again, no examples of using it.
Can someone post some code showing how to do this?
Thanks!
ErinBrimhall
Hi Kirk,
I do not have a network dataset or the supporting objects to test this, but I believe what you want to do is cast your INetworkLoader3 object as INetworkLoaderProgress_Events and subscribe to the Step and PutMessage events.  Inside the event-handlers is where you could presumably add your logic for updating the UI with progress info for the user.
For example:
INetworkLoader networkLoader = new NetworkLoaderClass();
(networkLoader as INetworkLoaderProgress_Event).Step += NetworkLoader_Step;
(networkLoader as INetworkLoaderProgress_Event).PutMessage += NetworkLoader_PutMessage;
protected void NetworkLoader_Step()
     // Update UI here.
protected void NetworkLoader_PutMessage(esriNetworkLoaderProgress progress, string message)
     // Update UI here.
ErinBrimhall
Hi Kirk,
For example:
     // Update UI here.
     // Update UI here.
