Formatting Halo in Label Expression
4979
08-07-2014 01:09 PM
mpboyle
Occasional Contributor III
Does anyone know if it's possible to format a halo within a label expression?  For example, format the halo color like you would a font color.
Thanks in advance.
Mapperzmap
New Contributor III
It can be done
Label Script (Halo)
mpboyle
Which values within the code provided need to be swapped out with my data?
mpboyle
Through the label expression.  I'm trying to label two fields in the label expression, each with a white font, but DIFFERENT halo colors.
JohannesBierer
You can use two layers with the same data source and label both with different colours?
