I have an image working to fire some code and a button as well....I want to change the BUTTON below to something liek this and cant figure it out.
HTML:
<td align="center" id="DrawGraphics" class="tdHeader">
<img alt="Settings" src="imagesApp/PencilBlue.png" class="imgOptions" title="Draw" style="cursor: pointer" />
</td>
JAVASCRIPT
on(dojo.byId('DrawGraphics'), "click", DrawGraphics);
function DrawGraphics() {
if (action2 != undefined) {
action2.pause();
I WANT TO CHANGE THE BELOW TO fire with an image and not a big button.... any thoughts on this..can I get this toggle to run from an image click instead of a button....
HTML
<td align="left" id="Imagery" class="tdHeader">
<button id="programmatic"></button>
</td>
JAVASCRIPT
base1 = new ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer", {
visible: true
base2 = new ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer", {
visible: false
app.map.addLayers([base1, base2]);
new ToggleButton({
showLabel: true,
checked: false,
onChange: function (val) {
base1.setVisibility(!val);
base2.setVisibility(val);
},"programmatic");
Solved! Go to Solution.
DGIFMapping_2.js
on(dojo.byId('Imagery').children[0], "click", changeBasemap);
function changeBasemap(){
if(base1.visible){
base1.setVisibility(false);
base2.setVisibility(true);
}else{
base1.setVisibility(true);
base2.setVisibility(false);
DGIFMapping_2.html
<td align="center" id="Imagery" class="tdHeader">
<img src="imagesApp/Layers2.png" title="Basemap" style="cursor: pointer"/>
</td>
Jay,
What specifically are you having trouble with? You already have the code that is needed to attach to the images click function...
DGIFMapping_2.js
if(base1.visible){
}else{
DGIFMapping_2.html
</td>
That was it....I was still trying to use the Toggle inside a function which was screwing me up...
The IF ELSE statement does just fine....
THANKS....again....
Jay,
You can also shorthand this function by removing the if statement and just using these two lines:
base1.setVisibility(!base1.visible);
base2.setVisibility(!base2.visible);
Some may like it better the other way for readability, but I like shorter code.
