AnsweredAssumed Answered
grid select example
Question asked by jay.kapalczynski on Aug 5, 2014
Latest reply on Nov 12, 2015 by dafiter
I am using this example...
DataGrid with zoom button | ArcGIS API for JavaScript
I replaced the reference of the polygon Map Service with my own and it works FINE.
I then try it with a Point Feature and it breaks...
Is there something I am doing wrong for the Point feature...I replaced the SELECTION symbol for that of a point
Looking to modify this for both a point and line feature....
var StatesGrid = declare([Grid, Selection]);
        var columns = [{
          label: "",  //wasn't able to inject an HTML <div> with image here
          field: "OBJECTID",
          formatter: makeZoomButton
          label: "unknown",
          field: "SITENAME"
        //restrict sorting to the state name field
        for (var i = 0; i < columns.length; i++) {
          if (i == 1) {
            columns[i].sortable = true;
          } else {
            columns[i].sortable = false;
        grid = new StatesGrid({
          bufferRows: Infinity,
          columns: columns
        }, "grid");
//add the states demographic data
        var statesLayer = new FeatureLayer("https://fwisweb1.dgif.virginia.gov/arcgis/rest/services/Public/DGIF_Public/FeatureServer/1", {
          mode: FeatureLayer.MODE_SELECTION,
          outFields: ["OBJECTID", "SITENAME"]
//define a selection symbol
        var GridSelectsymbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([0, 0, 255, 0.5]),
            6
          new Color([0, 0, 255])
statesLayer.setSelectionSymbol(GridSelectsymbol);
        statesLayer.on("load", function(evt) {
          var query = new Query();
          query.where = "1=1";
          evt.layer.queryFeatures(query, function(featureSet) {
            var items = array.map(featureSet.features, function(feature) {
              return feature.attributes;
            //idProperty must be set manually if value is something other than 'id'
            var memStore1 = new Memory({
              data: items,
              idProperty: "OBJECTID"
            window.grid.set("store", memStore1);
            window.grid.set("sort", "SITENAME");
            grid.on(".field-OBJECTID:click", function(e) {
              //retrieve the ObjectId when someone clicks on the magnifying glass
              if (e.target.alt) {
                zoomRow(e.target.alt);
        app.map.addLayers([statesLayer]);
function makeZoomButton(id) {
          //set the feature 'id' as the alt value for the image so that it can be used to query below
          var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='images/ArrowUp.png' alt='" + id + "'";
          zBtn = zBtn + " width='18' height='18'></div>";
          return zBtn;
     function zoomRow(id) {
          statesLayer.clearSelection();
          var query1 = new Query();
          query1.objectIds = [id];
          statesLayer.selectFeatures(query1, FeatureLayer.SELECTION_NEW, function(features) {
            //zoom to the selected feature
           var stateExtent = features[0].geometry.getExtent().expand(2.0);
           app.map.setExtent(stateExtent);
Outcomes
