Multiple Windows in ArcGIS
4986
7
08-06-2014 04:55 AM
WalterWitt
New Contributor III
In previous versions of Arc and previous computers, I have been able to open as many Arc Projects as I want, each in its own window. In my current situation, I can only open one Project at a time. If I want to open a new Arc project, I have to save the one I am using and close it.
What to do?
AdrianWelsh
MVP Honored Contributor
When you say multiple projects, are you meaning multiple instances of separate ArcMap programs running at the same time?  What version of ArcGIS are you running and what is your operating system?  What happens when you have ArcMap running and then go to Start --> ArcGIS --> ArcMap on your computer?
WalterWitt
New Contributor III
Adrian
As I stated in my original enquiry, I am running ArcGIS9.3.1 on a Windows 8 platform. When I go Start – ArcGIS – Arcmap, the current Project (map) closes down and the new one opens up
Walter
ZackK
New Contributor III
Hello Walter,
Try this solution:
http://blogs.esri.com/esri/supportcenter/2010/07/21/after-installing-service-pack-2-for-9-3-1-openin...
As you see, this bug precedes Windows 8, so I hope the solution works for you as well.
Good luck!
WalterWitt
New Contributor III
Zack
Thanks for your help. It does not seem a very satisfactory state of affairs though
Regards
Walter
ZackK
New Contributor III
Glad I could provide some insight, I had the issue soon after the service pack came out...
Cheers!
WalterWitt
New Contributor III
Service packs – more trouble than they are worth, generally speaking
Walter
ZackK
New Contributor III
Often they fix the bugs I didn't even know I had, and no fix for the ones that are bugging me (or create surprises as you had above)
