AnsweredAssumed Answered
gas price JSON mashup example - using generateRendererTask instead
Question asked by schlot on Aug 4, 2014
Latest reply on Apr 17, 2016 by musaserkan
I need to combine my JSON file to an existing featureLayer, adding additional attributes that I want to use to render my polygons.  I'm using the example https://developers.arcgis.com/javascript/jssamples/data_gas_prices.html  I have stepped through my graphics and at the end of that looping, my featureLayer has the new attributes I need.  That example is calculating the class breaks manually, but I'd like to use the generateRendererTask instead.
I know I am getting lost in the order of the events.  Once I have the new attributes I want to use one of them as the classification field for the renderer.  In the functions that I define it, it doesn't yet recognize that attribute as being available. Putting my breakpoints in right after I've looped through the graphics, I believe that it's there.  I'm not calling the render functions correctly, or I need to have an event listener set up for the featureLayer.  In the original example, there is an update-end listener on the featureLayer.  I"m not sure what that's for.  I have moved my call to generateClassBreaks to different positions, but I continue to get the error that it can't find my classification field "CROP", which is one of the attributes I introduced from the JSON file.
<!doctype html>
<html>
  <head>
    <title></title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <link rel="stylesheet" href="css/style.css">
    <script type="text/javascript" >var dojoConfig = {
      parseOnLoad: false,
      async:true,
          packages: [{
        location: location.pathname.replace(/\/[^/]+$/, "") + "/extras"
    </script>
    <script  type="text/javascript" src="http://js.arcgis.com/3.10/"></script>
      var pathName = "https://myserverURL";
      var defaultFrom = "#feedde";
      var defaultTo = "#e75303";
      var interval = 5;  //used to generate renderer
      require([
        "dojo/parser", "dojo/json",  "dojo/_base/array",  "dojo/_base/connect",  "esri/Color",
        "dojo/number",  "dojo/dom-construct",
        "esri/map",  "esri/geometry/Extent","esri/SpatialReference", "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer", "esri/renderers/ClassBreaksRenderer",
        "esri/layers/FeatureLayer",  "esri/dijit/Legend",  "esri/request", "extras/Tip",
        "esri/tasks/ClassBreaksDefinition", "esri/tasks/AlgorithmicColorRamp",
        "esri/tasks/GenerateRendererParameters", "esri/tasks/GenerateRendererTask",
        "esri/layers/LayerDrawingOptions",
        "dijit/layout/BorderContainer",  "dijit/layout/ContentPane",  "dojo/domReady!"
      ], function(
        parser, JSON, arrayUtils, conn, Color, number, domConstruct,
        Map, Extent, SpatialReference, SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer, ClassBreaksRenderer,
        FeatureLayer, Legend, esriRequest, Tip,
        ClassBreaksDefinition, AlgorithmicColorRamp,GenerateRendererParameters, GenerateRendererTask, LayerDrawingOptions) {
          parser.parse();
          spatialReference = new SpatialReference({wkid: 102100 });
          var startExtent = new Extent(-10583000, 4287025, -9979000, 4980462, spatialReference);
          map = new Map("map", {
            extent: startExtent
     var  defaultSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([182, 182, 182]), 1), new Color([190, 190, 190, 0.7]))
      var template = "<strong>${COUNTYNAME}";
          tip = new Tip({
            "format": template,
            "node": "legend"
          featureLayer = new FeatureLayer(pathName+"/arcgis/rest/services/BaseMap/county_simple/MapServer/0", {
            maxAllowableOffset: map.extent.getWidth() / map.width,
            mode: FeatureLayer.MODE_SNAPSHOT,
            outFields: ["COUNTYNAME"],
            visible: true
          featureLayer.setRenderer(new SimpleRenderer(null));//starts empty
          var updateEnd = featureLayer.on("update-end", function() {
            updateEnd.remove();
            var def = esriRequest({
              // url: "http://apify.heroku.com/api/aaagasprices.json",
              url: "../json/agChemical2.json",
              callbackParamName: "callback"
           def.then(drawFeatureLayer, drawFeatureError);
            generateClassBreaks(defaultFrom, defaultTo);
            // wire up the tip
            featureLayer.on("mouse-over", tip.showInfo);
            featureLayer.on("mouse-out", tip.hideInfo);
          map.addLayer(featureLayer);
  function drawFeatureLayer(data) {
    var values = (typeof data === "string" ) ? JSON.parse(data) : data;
    arrayUtils.forEach(featureLayer.graphics, function(graphic) {
      var rec = values[graphic.attributes.COUNTYNAME];
       if (rec) {
        var recData = rec[0];
        var atts = [];
          for(var att in recData){
            atts.push(att);
            var field = att;
          //    console.log ('att = ' + att + ", value = " + recData[att]);
            graphic.attributes[att] = recData[att];
  domConstruct.destroy("loading");
 //functions for generating symbology for the layer selected
  function generateClassBreaks(c1, c2) {
    var classDef = new ClassBreaksDefinition();
    classDef.classificationField = "CROP";
    classDef.classificationMethod = "quantile";
    classDef.breakCount = interval;  //defined as 5
    var colorRamp = new AlgorithmicColorRamp();
    colorRamp.fromColor = new Color.fromHex(c1);
    colorRamp.toColor = new Color.fromHex(c2);
    colorRamp.algorithm = "hsv"; // options are:  "cie-lab", "hsv", "lab-lch"
    classDef.baseSymbol = defaultSymbol;
    classDef.colorRamp = colorRamp;
    var params = new GenerateRendererParameters();
    params.classificationDefinition = classDef;
  //  params.precision = 2;
 //   params.formatLabel = true;
//    var clauseInput = classDef.classificationField;
 //   params.where= clauseInput + " > 0";
    var generateRenderer = new GenerateRendererTask(featureLayer);
    generateRenderer.on("error", taskErrorHandler);
    generateRenderer.execute(params, applyRenderer);
  function applyRenderer(renderer) {
    var optionsArray = [];
    renderer.defaultSymbol = defaultSymbol;
    var drawingOptions = new LayerDrawingOptions();
    drawingOptions.renderer = renderer;
    optionsArray[0] = drawingOptions;
    agLayer.setLayerDrawingOptions(optionsArray);
    featureLayer.redraw();
 //   getInfoFromRender(renderer);//creates arrays the legend will use
 //  createLegend();
    function taskErrorHandler(err){
     console.log("error in task is " + err.error);
          // function used by the class breaks renderer to get the
          // value used to symbolize each state
          function findBreakValue(graphic) {
ntyValues[COUNTY];
          function calcBreaks(min, max, numberOfClasses) {
            var range = (max - min) / numberOfClasses;
            var breakValues = [];
            for ( var i = 0; i < numberOfClasses; i++ ) {
              breakValues[i] = formatNumber(min + ( range * i ));
            // console.log("break values: ", breakValues);
            return breakValues;
          function formatNumber(num) {
            return number.format(num, { "places": 2 });
          function drawFeatureError(e) {
            console.log("error getting data: ", e);
    </script>
  </head>
  <body>
    <div id="loading" class="shadow loading">
      Getting Data...
      <img src="http://dl.dropbox.com/u/2654618/loading_gray_circle.gif" alt="loading image">
    </div>
    <div id="legend" class="shadow info"></div>
    <div data-dojo-type="dijit.layout.BorderContainer"
         data-dojo-props="design:'headline',gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="map"
           data-dojo-type="dijit.layout.ContentPane"
           data-dojo-props="region:'center'">
        <div id="title" class="shadow info">Current Values by County</div>
      </div>
    </div>
  </body>
</html>
Outcomes
