Is geoprocessing service 64 bit or 32 bit?
3588
08-03-2014 09:10 PM
anjelinaponkerat
Occasional Contributor II
Hi
Is geoprocessing service (in ArcGIS Server 10.2.2)  64 bit or 32 bit?
When I run my geoprocessing service by Background geoprocessing 64 bit, my model run on 4 seconds, but when I publish my model to ArcGIS Server and run by my web application it take 6 minutes time!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Please help me.
Regards
A.ponkerat
AndrewValenski
GP Services run as 64 bit operations
-Andrew
VinceAngelo
Esri Esteemed Contributor
This isn't an apples-to-apples comparison, and application bit size doesn't really have any bearing.
ArcGIS Server is a 64-bit application, but there are a number of factors that come into play:
  • The geoprocessing job needs to be queued, then taken off the queue
  • There may not be a started service available
  • The scratch workspace associated with the job needs to be created
  • The CPU class of the server is likely different from the desktop
  • The disk characteristics on the server is likely different from the desktop
You can add Verbose level logging to your app to break out the timing of the elements of the job, but logging can increase runtime, so that can be a two-edged sword.
- V
