Cost Distance Extent Problem
3654
6
08-04-2014 03:15 AM
Juan_Poblete
Hi! I am kind of new to ArcGIS and I would appreciate some help
I am carrying a cost path analysis over a piece of land and i am getting a strange answer I can not turn it right. I am assessing the least costly path between a coastal town -destination- and a series of three volcanoes -source- (based on which I created a cost distance raster). The boundary of the image attached shows the coast line. The resulting least costly path runs over the sea instead of facing directly a shorter path towards the closest volcano.
I suspect It has something to do with the extent and environmental setting of the cost distance or cost path tool. But I can not get it right.
Any help greatly appreciated!
RobertScheitlin__GISP
Juan,
   After doing more research you should actually be setting the water cells to NoData.
Cell locations with NoData in the input cost raster act as barriers in the cost surface functions. Any cell location that is assigned NoData on the input cost surface will receive NoData on all outputs (cost distance raster and, optionally, cost backlink raster).
You can also use one of the extract by tools to create another raster to set a boundary to your analysis
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Extract_by_Polygon/009z0000002q000000/
Juan,
   You have to assign the highest value to cells that are in the water in your weighted raster so that the analysis will not choose to go that route. Let me know if you don't understand.
Juan_Poblete
Thank you Robert.
I get your point. I gave it a try to a couple of attempts this morning by only changing the cell value, but it did not work. So far I have been only using a slope raster in order to create the cost distance surface. I have not used a landuse raster that can give me the chance to give a high value to cells in water.
I will search for a landuse raster and follow the way you suggest and let you know. Thanks!
Juan,
Juan_Poblete
Thank you Robert,
TimothyHales
Esri Notable Contributor
I've moved your post into the Spatial Analyst space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Timothy
Juan,
   Glad I could help. Now you can help by marking my reply about the no data as the "Correct Answer". Just click on the link that looks like this on my reply.
