Alesinar
Could someone check if this is correct, please?
Discussion created by Alesinar on Jul 31, 2014
Latest reply on Aug 4, 2014 by Alesinar
I have two lists:
A=[0, 45, 90, 135, 180, 225, 270, 315, 360]
k8=[4.729216146562631, 4.979995034716688, 5.83433020080749, 5.834682335428627, 5.555339121638964, 4.292788277464533, 5.875322012861815, 5.214309700178062]
As I started using python recently I developed one very inelegant code (below). The aim is to do calculation with every element of k8 if the element of A falls within certain angle defined by az. So if g is between az-45 and az+45 it will be multiplied by 1 and so on. The results of the multiplication are then appended to empty list k9. At the end the code should check at which place in list (k9) is the highest element and exstract value at the same place from another list (k1).
The code runs without errors, however I'm not certain if it produces correct results and if it will do so with any az. Could please some one with experience check if the code is correct. Also if someone knows a better solution for the problem, go ahead.
    for g in A:
        for h in k8:
            bz1=az-45
            if bz1<0:
                bz1=bz1+360
            bz2=az+45
            if bz2>360:
                bz2=bz2-360
            if g>bz1 and g<bz2:
                k=h*1.0
                k9.append(k)
            bz3=az-90
            if bz3<0:
                bz3=bz3+360
            bz4=az+90
            if bz4>360:
                bz4=bz4-360
            if g>bz3 and g<bz4:
                k=h*0.75
                k9.append(k)
            bz5=az-135
            if bz5<0:
                bz5=bz5+360
            bz6=az+135
            if bz6>360:
                bz6=bz6-360
            if g>bz5 and g<bz6:
                k=h*0.5
                k9.append(k)
            bz7=az-135
            if bz7<0:
                bz7=bz7+360
            bz8=az+135
            if bz8>360:
                bz8=bz8-360
            if g<bz7 and g>bz8:
                k=h*0.25
                k9.append(k)
            break
    ll=len(k9)
    print ll
    print k9
    def highestNumber(k9):
        myMax = k9[0]
        for num in k9:
            if myMax < num:
                myMax = num
        return myMax
    print highestNumber (k9)
    smer=k9.index(highestNumber (k9))
    print smer
    czk=k1[smer]
Outcomes
