Summerize attribute fields in new row, then add as new field to another shapefile
2931
07-31-2014 12:28 PM
ChelseyAiton1
I am interested to know if someone could help me figure out this problem for a class project.
I have done some analysis:
I would like to insert a new row that has the sum of each attribute field. I have tried using summary statistics tool but only get an error in the statistics field(s) parameter. I would also need to automate this process because in some cases there are 50 parks in the layer.
                    Park 1_ sales     Park 1 _prob     Park 2_sales     Park 2_ prob     (made up numbers to show layout)
                         3                                   .2                    6                    .9
                         5                                   .6                    9                    .6
New row: Sum=  8                                   .8                    15                   1.5
    Then,  I have the park layer. I would like to create two new fields and populated them with the summary row information
               sales     prob
Park 1          8          .8
Park 2        15          1.5
Please let me know if you have any advice or if I need to be clearer.
DanPatterson_Retired
ChelseyAiton1
I was able to figure out the first half of the problem and create a script to automate the process. The second half is the tricky part. Have a horizontal row become two vertical columns...
http://www.pinterest.com/pin/create/extension/
Do you mean the Transpose tool ?
ChelseyAiton1
http://www.pinterest.com/pin/create/extension/Dan,
Yes thank you! I had not heard of or stumbled upon this tool in my research.
Chelsey, closing the thread would help others find a solution, if the help did indeed resolve your issue
