Selectable services in Operations Dashboard
3010
07-31-2014 12:07 PM
MarkChambers1
I can only set a feature service as selectable.  I cannot set a map service as selectable. Any reason for this.  Am I missing something?
Thank you,
Mark Chambers
Kylie
by Esri Regular Contributor
Hi Mark -- If you added the entire map service to the map, that is the expected behavior. If you want layers in a map service to be selectable, you can add them to the map directly, instead of adding them as part of a map service.
Please see the Note in Supported data types in Data sources in the operation view—Operations Dashboard for ArcGIS | ArcGIS‌ for details on adding a layer from a map service vs adding a map service.
Esri Education Team
