Is there a way to display a scale ratio instead of bar in AGOL?
I published a service (from ArcServer 10.1) from an MXD with labels that turn on and off at different scales. They look fine in my MXD but don't quite do what I want in the AGOL map viewer. If AGOL displayed the scale as a ratio it’d be easy to re-set the MXD values and republish. With just the scale bar it’ll take several iterations of random tweaking and publishing until I get what I need.
Tycho
Go to Details -> Show Contents of map and view description of your base map.
Look for map contents, which is actually a rest map service end point
Open the rest end point, and look for level details that's where you'll find your scale ratio.
