Warning: org.apache.cxf.endpoint.ServerImpl
6956
07-29-2014 11:25 AM
GregYetman
With a clean install of GeoEvent Server 10.2.2 I get 21 warnings in the log file after starting it. The first looks like a conflict:
Registering ManagedEndpoint failed. javax.management.InstanceAlreadyExistsException:
The full stack is at the end of the message. The next 20 are all the same:
org.apache.cxf.interceptor.security.SecureAnnotationsInterceptor The roles map is empty, the service object is not protected
Are these safe to ignore? Is there a conflict somewhere?
TIA, Greg
Registering ManagedEndpoint failed. javax.management.InstanceAlreadyExistsException: org.apache.cxf:bus.id=cxf942022530,type=Bus.Service.Endpoint,service="{http://provider.service.rest.ges.esri.com/}DefaultServiceProvider",port="DefaultServiceProvider" at com.sun.jmx.mbeanserver.Repository.addMBean(Unknown Source)[:1.7.0_51] at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerWithRepository(Unknown Source)[:1.7.0_51] at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerDynamicMBean(Unknown Source)[:1.7.0_51] at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerObject(Unknown Source)[:1.7.0_51] at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerMBean(Unknown Source)[:1.7.0_51] at com.sun.jmx.mbeanserver.JmxMBeanServer.registerMBean(Unknown Source)[:1.7.0_51] at org.apache.cxf.management.jmx.InstrumentationManagerImpl.registerMBeanWithServer(InstrumentationManagerImpl.java:331) at org.apache.cxf.management.jmx.InstrumentationManagerImpl.register(InstrumentationManagerImpl.java:321) at org.apache.cxf.management.jmx.InstrumentationManagerImpl.register(InstrumentationManagerImpl.java:234) at org.apache.cxf.management.jmx.InstrumentationManagerImpl.register(InstrumentationManagerImpl.java:246) at org.apache.cxf.management.jmx.InstrumentationManagerImpl.register(InstrumentationManagerImpl.java:239) at org.apache.cxf.endpoint.ServerImpl.initDestination(ServerImpl.java:107) at org.apache.cxf.endpoint.ServerImpl.<init>(ServerImpl.java:72) at org.apache.cxf.jaxrs.JAXRSServerFactoryBean.create(JAXRSServerFactoryBean.java:151) at com.esri.ges.rest.service.spring.JAXRSServiceBean.restartServices(JAXRSServiceBean.java:171) at com.esri.ges.rest.service.spring.JAXRSServiceBean.init(JAXRSServiceBean.java:99) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.7.0_51] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)[:1.7.0_51] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)[:1.7.0_51] at java.lang.reflect.Method.invoke(Unknown Source)[:1.7.0_51] at org.apache.aries.blueprint.utils.ReflectionUtils.invoke(ReflectionUtils.java:225)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BeanRecipe.invoke(BeanRecipe.java:838)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BeanRecipe.runBeanProcInit(BeanRecipe.java:638)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BeanRecipe.internalCreate(BeanRecipe.java:726)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.di.AbstractRecipe.create(AbstractRecipe.java:64)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BlueprintRepository.createInstances(BlueprintRepository.java:219)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BlueprintRepository.createAll(BlueprintRepository.java:147)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BlueprintContainerImpl.instantiateEagerComponents(BlueprintContainerImpl.java:631)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BlueprintContainerImpl.doRun(BlueprintContainerImpl.java:337)[22:org.apache.aries.blueprint:0.3.2] at org.apache.aries.blueprint.container.BlueprintContainerImpl.run(BlueprintContainerImpl.java:230)[22:org.apache.aries.blueprint:0.3.2] at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)[:1.7.0_51] at java.util.concurrent.FutureTask.run(Unknown Source)[:1.7.0_51] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)[:1.7.0_51] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)[:1.7.0_51] at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)[:1.7.0_51] at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)[:1.7.0_51] at java.lang.Thread.run(Unknown Source)[:1.7.0_51]
