field calculator error
528
07-25-2014 09:56 AM
LefterisKoumis
Occasional Contributor III
I am novice in python and I am trying to run a function in the field calculator and I get this error. It drives me nuts. What is wrong?
Thank you.
Error:
error 000539: syntaxerror: invalid syntax (<expression>, line 1)
Pre-Logic Script Code:
def fnfindstation(addstation):
  if addstation == "151" or addstation == "551":
   formataddress ="Oleander Station 1 - Shift B"
  elif addstation == "152" or addstation == "552":
    formataddress ="Oleander Station 2 - Shift B"
  else:
    formataddress = "Outside Station"
  return formataddress
Station =
fnfindstation=( !district!)
Tags (1)
IanMurray
since you are calling a function on a field, there is no need for an equal sign, since you are not setting a variable in your expression.
instead of
try
fnfindstation(!district!)
IanMurray
instead of
try
LefterisKoumis
Huh... I knew it was something simple.. has to get used to Python since it is so different that other languages. Thank you.
