AnsweredAssumed Answered
Esri token URL keeps changing host IP address. Whats the work around?
Question asked by rodwell on Jul 24, 2014
Latest reply on Mar 18, 2015 by bixb0012
We are having a problem where for one of our clients our
application that uses ArcGIS is failing to connect to your services. We
have looked into this issue and realised that every time we request a
token from within our application the HOST IP address keeps on changing
e.g look at the calls list below. Same call but different IP address
each time. The clients environment is highly secure and they need
upfront to allow access for certain IP addresses but now if it’s going
to be changing for the same URL how do we get around this. Unfortunately
they can not just open up their network.  I thought you would have
static IP addresses for your URLs but this is not the case. If you may
please let me know a workaround to this it would be great.
The url we are using is
https://www.arcgis.com/sharing/oauth2/token?client_id=******&grant_type=client_credentials&client_secret=*****&f=pjson
HTTPS-SERVER-CIPHER: TLS1_CK_ECDHE_RSA_WITH_AES_128_CBC_SHA
HTTPS-SERVER-SESSIONID: 70 44 98 7F 6E 73 FF 09 43 5A D4 F0 6A 18 81 A5 CF A2 99 76 18 1E 03 18 63 4C C1 B8 D9 C3 0C 39
X-CLIENTIP: 127.0.0.1
X-CLIENTPORT: 63800
X-EGRESSPORT: 63801
X-HOSTIP: 54.243.139.226
HTTPS-CLIENT-SNIHOSTNAME: www.arcgis.com
X-CLIENTPORT: 63547
X-EGRESSPORT: 63548
X-HOSTIP: 54.225.191.183
X-CLIENTPORT: 64528
X-EGRESSPORT: 64529
X-HOSTIP: 54.225.173.54
For
the routing calls it seems you only use 2 IP addresses which is better
as they can allow access to these. The addresses we have picked up are
  1. 107.20.213.176 port 80
  2. 50.17.206.162 port 80
Outcomes
