I downloaded this arcscript from here: Filename Insert
It's an old script from 2006 and when I run it I get the following error:
File "C:\FileNameInsert.py", line 15, in <module>
import win32com.client, sys, string, os
ImportError: No module named win32com.client
How do I modify this script so it works in 2014?
(what I hoping to achieve is to add a filename attribute to my shapefiles so that when I merge them together I can trace back to the originals)
Solved! Go to Solution.
again...not tested...try this
import arcpy
# Remember to change this to wherever your shapefiles are stored
arcpy.env.workspace = r"C:\temp2"
fcs = arcpy.ListFeatureClasses()
for fc in fcs:
print fc
# Create the new field
arcpy.AddField_management (fc, "FILENAME", "text", "", "", "50")
# Apply the filename to all entries
arcpy.CalculateField_management (fc, "FILENAME", '"' + fc + '"')
#print arcpy.GetMessages ()
There seems to be something with the try..except block
import arcpy
Then replace gp. through arcpy.
Thanks - that kind of makes sence but the script isn't doing anything. It runs without error but doesn't add the new field.
Did you download the script? Can I ask some questions?
I removed line 17:
gp = win32com.client.Dispatch...............
was I correct to do this?
I don't understand the 'try:' section....it says:
try:
fcs = arcpy.ListFeatureClasses("*", "all")
fcs.reset()
rc = fcs.Next()
Why does it define fcs and then reset it on the next line? What is it doing?
I'll be happy if you can recommend a place where I can read up on these terms.
Regards
Ben
These two lines don't work in arcpy
fcs.reset()
rc = fcs.Next()
you might be advised to copy the script to your thread rather than relying on people downloading it themselves. The translation from 9.x to 10.x isn't simply a matter of replacing gp with arcpy, there are other issues
Good plan - my Arc machine isn't connected to the internet so usually it's a pain in the neck. I forgot that I had downloaded the code off the internet.
This is the code after my changes........
#import relevant modules, create geoprocessing dispatch object
import arcpy
#gp = win32com.client.Dispatch("esriGeoprocessing.gpDispatch.1")
arcpy.workspace = "C:\temp2"
try:
fcs.reset()
fc = fcs.Next()
while fc:
fc = fcs.Next()
except:
On a quick look (can't test)
arcpy.workspace = "C:\temp2" #should be "C:/temp2 python uses forward slashes
# amongst other things, ie raw notation r"C:\temp2
try:
#fcs = arcpy.ListFeatureClasses("*", "all")
fcs = arcpy.ListFeatureClasses() #is all that is needed in your case
#fcs.reset() #these two lines don't work in 10
#fc = fcs.Next()
remove one more fcs.Next line further down
What shoul I do to correct the while function, it still refers to fc.
IndentationError:unindent does not match any outer indentation level
Without the .Next lines how does the code know to iterate through all by shapefiles?
sorry - I still need to be spoon fed this stuff.
arrrgh need arcmap handy
replace the while line with
for fc in fcs: #keep the proper indentation!
and your homework is to ensure that you have the appropriate syntax in CalculateField management in case it has changed
Closer....closer....
I'm now getting some results but if I have several shapefiles in c:/temp2 the script only amends the last one (print fc lists all files correctly)
This is my code now:
import arcpy
try:
for fc in fcs:
print fc
except:
I think this is better than rewriting?
# Import arcpy module
import arcpy
# Set Geoprocessing environments
arcpy.env.workspace = "C:\\temp2"
for fc in fcs:
print fc
# Process: Feld hinzufügen
arcpy.AddField_management(fc, "FILENAME", "TEXT", "", "", "100", "", "", "NON_REQUIRED", "")
# Process: Feld berechnen
arcpy.CalculateField_management(fc, "FILENAME", "fc", "PYTHON", "")
