Operational Dashboard does not support custom basemaps with custom Spatial references?
3446
07-20-2014 11:36 PM
Myoung-okYoo
Does Operational Dashboard support custom basemaps with custom Spatial references?
It could not display on the map widget.
It displays only basemaps of 102100(3856)
Thank you.
Tags (1)
StephanKünster
Occasional Contributor II
This seems to be a current limitation of some of the ArcGIS client apps like Operations Dashboard or the Esri Maps for XY client apps. We encountered similar problems when using Esri Maps for Office with a custom basemap (ETRS89, 25832) provided by a Portal for ArcGIS. Don't know if there's a way to work with different coordinate systems in these clients at the moment. Hopefully there will be a way in the near future?
Portal for ArcGIS
Esri Maps for Location Analytics
Operations Dashboard for ArcGIS
Cheers,
Stephan
