broken links in MXD files as data in new server
2511
6
07-17-2014 11:43 AM
jackwalker
Hi guys ,
i am not sure if this is in the right section to post , this , i m struggling with the new set up here , But maybe some one can give me some help.
So i am working as map technian and i am in charge of my departments maps. My company has a base in a couple of different countires and we have been sharing some folders on the same server.
Recently the other country moved one folder to a new server without telling my country. So all of the links for these maps are broken . There is a lot. i have been trying to find some information about updating the links , i know that you can manually go into the MXD and then repair the link . But i have over 2000 , in lots of differet sub folders.
my data people here say that becuase its a server change , then its not possible to use a script to change the links automatically is this correct .
i was just looking for anyone who might have some insight in to this , thanks a lot
BrandonColeman
New Contributor III
You might want to look into the arcpy.mapping package and sections about either repairing broken data sources or by finding and replacing data sources.  That is off the top of my head.
I have in the past used arcpy.mapping for a find/replace option on my sources within my map document.  Basically, I said if the source equaled ("C:\data") then change it to ("S:\data").
It might get tricky depending on the structure change and what you mean by server change.
What I described above is based on using a network server that has shared drives.  However, if you are talking about changing the server like a new ArcGIS Server instance, then I am not sure.
However, I would still recommend looking into the arcpy.mapping package as it should have some of the tools to rectify this.
jackwalker
Hi Brandon ,
i am not sure about the server specifics , but i think its on another system server as in changing from a windows one to a unix  one .So i m not sure if this would effect the process
Mapperzmap
New Contributor III
You can fix some using the Map Path Editor
ArcGIS Server Help
jackwalker
hi map ,
thanks for the post . i will try this but this looks a little bit manually ideally i m looking a way of automatic putting something in place rather than copy and pasting each link
AnthonyGiles
by Anonymous User
Not applicable
Hi Jack,
Here are a couple of links to the Help resources regarding using Arcpy to repair data sources for multiple layers.  Hope this helps!
Sarah
Using Arcpy to Repair Data Sources for Multiple Datasets: ArcGIS Help 10.1
and
Additional info for using Arcpy to Repair Data SourcesArcGIS Help 10.1
