Spatial ETL Tools won't run "AttributeError: 'module' object has no attribute, etc."
5357
17
07-15-2014 08:45 AM
ChrisRado
I have a python script that runs 5 Spatial ETL tools that I wish to run as a scheduled task.
Each of the tools will run successfully from ArcCatalog and also from the ArcCatalog Command line.
If I try to run the tools from the DOS window, as would be done via python script for a scheduled task, arcpy cannot find the tools, although it does load the toolbox.
In the attached screenshot: 1) I open a cmd.exe window; 2) start python; 3) import arcpy; 4) Import my toolbox, which is verified as loaded on the next line; 5) Use arcpy.ListTools to see what tools are loaded. the result is "[]", meaning no tools are recognized from this tool box; 6) I use the same ListTools to show the Spatial Analyst tools that were loaded by import arcpy; 7) I attempt to execute one of the tools from my toolbox and forget a " (my mistake!); 😎 I attempt to execute one of the tools from my toolbox and receive the message "AttributeError: 'module' object has no attribute 'CopyFeatureClass_newgpetl'".
What is preventing my tools from being recognized from the DOS CMD.EXE window while ArcCatalog and ArcCatalog Command Line can run them?
ChrisRado
Just for anyone who comes across this same problem and searches out this discussion:
The key thing that I am missing (in this case) that causes the "AttributeError: 'module' object has no attribute..." is that I forgot to check out the Data Interoperability extension, with this:
arcpy.CheckOutExtension("DataInteroperability")
This fixed the problem on my local machine, but it did not fix the problem on our server. When I figure that out, I'll add a note about what it was to this discussion.
KristiBarry
Please share any results you may have.  I am not able to make this work even after executing (and verifying) the arcpy.CheckOutExtension("DataInteroperability") has checked out the extension.  We are getting the same AttributeError everyone else seems to be seeing on this problem.
thanks,
Kristi
ChrisRado
Kristi,
This is why Spatial ETL Tools are NOT being recognized on the server- in our particular case.
NIM09073:
"When calling a model with Python that contains a Data Interoperability Spatial ETL tool, the script will not run successfully from IDLE when Esri Production Mapping 10.1 is installed."
Spatial ETL Tools will not run if you have Workflow Manager (aka Esri Production Mapping) installed on the same machine. If I uninstall Workflow Manager and try the tools again, they become visible at the Windows command line.
I'm assuming you have already been through:
1) Proper names for Toolbox Name (no spaces) and Toolbox Label (any crazy thing you want).
2) Adding an all lower case Toolbox Alias
3) Proper names for Tool Name (no spaces) and Tool Label (any crazy thing you want).
Chris
SrijanaTuladhar
New Contributor III
Hi Chris,
I am getting the same attribute error, even after adding the arcpy.CheckOutExtension("DataInteroperability") into the script.
The error message.
  File "G:\....\Scripts\ETL_mb_test5.py", line 21, in <module>
    arcpy.SpatialETLTool_test("G:\\....\\Source42015.gdb")
AttributeError: 'module' object has no attribute 'SpatialETLTool_test'
Here is the python script:
# Import arcpy module
import arcpy
# Load required toolboxes
arcpy.ImportToolbox("G:/..../testETLtool.tbx")
# Check out extension
# Local variables:
Source42015_gdb = "G:\\.....\\Source42015.gdb"
# Process: SpatialETLTool
arcpy.SpatialETLTool_test("G:\\.......\\Source42015.gdb")
Thanks for your help.
Sri
BruceHarold
Hi
Do you have the Workflow Manager extension installed?  There is a known incompatibility fixed in 10.3.1 that results in Data Interoperability tools not being licensed when Workflow Manager is present.
Regards
SrijanaTuladhar
New Contributor III
Hi Bruce,
No, I do not have Workflow Manager extension installed.
Sri
BruceHarold
Please check you have an alias 'test' set for the Toolbox containing your ETL tool - that is the value indicated by your Python code.  If you do then you need to log a support call because something else is wrong.
SrijanaTuladhar
New Contributor III
Ok thanks. Yes, I just double checked, I have an alias 'test' for the Toolbox that contains the ETL tool.
ChrisBlinn1
Also having this issue.
Workflow Manager and Production Mapping are not installed.
Checked out extension.
Toolbox has alias, and model has name.
Runs from ModelBuilder and from python console in ArcCatalog 10.2.2
import arcpy
class LicenseError(Exception):
   pass
try:
   if arcpy.CheckExtension("DataInteroperability") == "Available":
   print "Checked out \"DataInteroperability\" Extension"
   else:
   raise LicenseError
except LicenseError:
   print "Data Interoperability license is unavailable"
except:
   print arcpy.GetMessages(2)
arcpy.ImportToolbox("C:/.../ETL.tbx")
# Script arguments
Source = arcpy.GetParameterAsText(0)
if Source == '#' or not Source:
  Source = "C:\\...\\Source.gdb" # provide a default value if unspecified
Destination = arcpy.GetParameterAsText(1)
if Destination == '#' or not Destination:
  Destination = "C:\\...\\Destination.gdb" # provide a default value if unspecified
FeatureTypes = arcpy.GetParameterAsText(2)
if FeatureTypes == '#' or not FeatureTypes:
  FeatureTypes = "Parcel_Project" # provide a default value if unspecified
# Local variables:
# Process: WalworthETL
arcpy.WalworthETL_ETL(Destination, Source, FeatureTypes)
