Problems loading data into ArcMap 10.0
4481
5
07-14-2014 10:11 AM
MelvinShuster
New Contributor III
Hello:
A couple of days ago I started having problems loading data into my ArcMap program. I now get the error message: "Failed to connect to database, An underlying database error occurred, class not registered." I believe that this started happening when I allowed Microsoft to make an update to my windows software.
Any help would be greatly appreciated.
Mel
StevenGriffith
New Contributor III
This is a connection issue between ArcMap and your database. Make sure your database name / userid / password / etc. in your connection are correct. Talk to your DBA (if this is not a file geodatabase), especially if "nothing has changed".
Leandro-Zamudio
What are you trying to connect or load into arcmap?
MelvinShuster
New Contributor III
Leandro:
Thanks for your interest in my problem. I found that if I resaved my excel file in an earlier version that it loaded fine into ArcMap.
Best,
Mel
DanPatterson_Retired
Other solutions can be found by searching on your error which may fix that problem, for example see
https://community.esri.com/message/273006?sr=search&searchId=4bccb531-edc0-4a32-a430-e9f70138c0b1&se...
NidhinKarthikeyan
Occasional Contributor III
