Calculating the normal vector of each TIN facet
2495
07-13-2014 09:35 AM
YufanMiao
Dear all,
I have a set of 3d points with x, y, z values. I would like to make TIN model (Delaunay triangulation is also fine for me )out of these points and calculate the normal vector of each TIN facet with ArcObjects, better in C sharp. Does anyone have an idea how I can achieve that?
Kind regards
Yvan
nicogis
MVP Frequent Contributor
for create a tin from point:
// Instantiate a new empty TIN.
ITinEdit TinEdit = new TinClass();
// Initialize the TIN with an envelope. The envelope's extent should be set large enough to
// encompass all the data that will be added to the TIN. The envelope's spatial reference, if
// if has one, will be used as the TIN's spatial reference. If it is not set, as in this case,
// the TIN's spatial reference will be unknown.
IEnvelope Env = new EnvelopeClass();
Env.PutCoords(0, 0, 10, 10);
TinEdit.InitNew(Env);
// Add points to the TIN. These will become triangle nodes.
IPoint Point = new PointClass();
Point.X = 2;
Point.Y = 2;
Point.Z = 0;
TinEdit.AddPointZ(Point, 0);
Point.Y = 7;
Point.X = 7;
// Save the TIN to disk. The overwrite parameter is used to indicate whether an existing
// TIN with the same name is allowed to be replaced with this one.
object overwrite = true;
TinEdit.SaveAs("c:\\data\\my_tin", ref overwrite);
when you have tin you get triangle component and use ITinTriangle.QueryNormal ( ArcObjects Help for .NET developers‌ )
