AnsweredAssumed Answered
How to tell if two shapefiles overlap?
Question asked by Jack93 on Jul 9, 2014
Latest reply on Jul 9, 2014 by Jack93
Hi there, I'd like to create a column in an attributes table which works out if each particular polygon overlaps with a polygon from a particular other shapefile. So for example, I'd have two different shapefiles, one showing areas colonised by a particular plant species and another showing areas where a particular farming method is used. I'd then like to have a column in the attributes table of the plant which will say for each individual polygon whether it overlaps with a polygon for the farming method. Is it possible to do this with ArcGIS? It does seem that almost anything is possible! I've had a look around for an answer but I am fairly new to ArcGIS so I could well be looking in the wrong places, please let me know if that question is unclear. Thanks!your question
Outcomes
