if (evt.addresses.length > 0) { alert('there were results'); } else { alert('there were no results'); }
Solved! Go to Solution.
var h = 0; for( i = 0, i < h, i++){ //code will never get here }
if(evt.addresses){ //results exist }else{ //do nothing }
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Find Address</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ padding:0; border:solid 1px #343642; margin:5px 5px 5px 0px; } #leftPane{ width:20%; border-top: solid 1px #343642; border-left: solid 1px #343642; border-bottom: solid 1px #343642; margin:5px 0px 5px 5px; color: #343642; font:100% Georgia,"Times New Roman",Times,serif; /*letter-spacing: 0.05em;*/ } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map, locator; require([ "esri/map", "esri/tasks/locator", "esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/Font", "esri/symbols/TextSymbol", "dojo/_base/array", "esri/Color", "dojo/number", "dojo/parser", "dojo/dom", "dijit/registry", "dijit/form/Button", "dijit/form/Textarea", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, Locator, Graphic, InfoTemplate, SimpleMarkerSymbol, Font, TextSymbol, arrayUtils, Color, number, parser, dom, registry ) { parser.parse(); map = new Map("map", { basemap: "streets", center: [-93.5, 41.431], zoom: 5 }); locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"); locator.on("address-to-locations-complete", showResults); // listen for button click then geocode registry.byId("locate").on("click", locate); map.infoWindow.resize(200,125); function locate() { map.graphics.clear(); var address = { "SingleLine": dom.byId("address").value }; locator.outSpatialReference = map.spatialReference; var options = { address: address, outFields: ["Loc_name"] } locator.addressToLocations(options); } function showResults(evt) { var candidate; var symbol = new SimpleMarkerSymbol(); var infoTemplate = new InfoTemplate( "Location", "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}" ); symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE); symbol.setColor(new Color([153,0,51,0.75])); var geom; arrayUtils.every(evt.addresses, function(candidate) { console.log(candidate.score); // NEW if (evt.addresses.length > 0) { console.log(candidate.location); var attributes = { address: candidate.address, score: candidate.score, locatorName: candidate.attributes.Loc_name }; alert('results!'); geom = candidate.location; var graphic = new Graphic(geom, symbol, attributes, infoTemplate); //add a graphic to the map at the geocoded location map.graphics.add(graphic); //add a text symbol to the map listing the location of the matched address. var displayText = candidate.address; var font = new Font( "16pt", Font.STYLE_NORMAL, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "Helvetica" ); var textSymbol = new TextSymbol( displayText, font, new Color("#666633") ); textSymbol.setOffset(0,8); map.graphics.add(new Graphic(geom, textSymbol)); return false; //break out of loop after one candidate with score greater than 80 is found. } //NEW else { alert('no results'); } }); if ( geom !== undefined ) { map.centerAndZoom(geom, 12); } } }); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'sidebar', gutters:false" style="width:100%; height:100%;"> <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"> Enter an address then click the locate button to use a sample address locator to return the location for street addresses in the United States. <br> <textarea type="text" id="address"/>380 New York St, Redlands</textArea> <br> <button id="locate" data-dojo-type="dijit/form/Button">Locate</button> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Your if/else is inside your loop that uses evt.addresses as the parameter.
Since evt.addresses doesn't have any candidates when there are no results, the loop never fires.
evt.addresses.length will always be greater than 1 inside your loop.var h = 0; for( i = 0, i < h, i++){ //code will never get here }
