Filter Problem
3112
06-10-2014 03:16 PM
DarrylWilson
Hi there, I'm trying to create a filter to match on a literal string. However I keep getting the message "A Filter can not be created without expression(s). Please provide at least one expression to crerate a Filter."
Please see attached. [ATTACH=CONFIG]34488[/ATTACH]
AdamRepsher
Occasional Contributor III
Darryl,
It took me a minute to understand what was going on here.  I fumbled over this one for a day before I got it.
You built the expression, but now you need to 'add' it to the list of expressions below.  Just click on the green 'plus' sign (+) below the built expression, and you should be good to go!!!
I hope that helps!
--Adam
DarrylWilson
Thanks Adam, that worked.
