street color and thickness
430
05-07-2014 12:04 PM
johnbrosowsky
Occasional Contributor II
I have imported street centerlines from a shapefile.  By default, they appear as black lines with a dot at intersections.  How do I change the color, thickness, opacity, and remove the dot at the intersections?  I have figured it out for buildings, but not streets.  I just need a very simple scene, nothing complex at all.  Thanks!
LukeCzar
New Contributor III
When you import your data make sure you select "Create Street......"
[ATTACH=CONFIG]33670[/ATTACH]
